I have a datatype called alpha which is based on float64. Now I want to create a custom ROS2 message which has this datatype instead of adding float64. Is there a way to do this?
My code would look like:
alpha number;
msg.data = number;
I want my msg type to be:
alpha data
Custom ROS 2 messages are usually created using the basic message types which are supported by ROS 2. I don't think you can directly use your Alpha datatype to create a custom ROS 2 message.
However, you can use the basic datatypes which are provided to you by ROS 2 to recreate your Alpha datatype and then use that to create the custom datatype you want.
Method
For example, you can create a ROS 2 package with a directory structure similar to the one below.
src
└── alpha_msgs
    ├── CMakeLists.txt
    ├── include
    ├── msg
    │   ├── Alpha.msg
    │   └── AlphaArray.msg
    ├── package.xml
    └── src
Let's say you want to create an Alpha array datatype called AlphaArray. You can first define your alpha datatype from scratch.
# Alpha.msg
float64 direction
float64 magnitude
Then you would use the custom Alpha datatype to create another custom array datatype such as AlphaArray.
# AlphaArray.msg
Alpha[] data    # An array of Alpha.msg types
Then it's just a matter of specifying how your package should be built in the CMakeLists.txt and adding some dependencies to the package.xml file. The CMakeLists.txt would look something like this.
cmake_minimum_required(VERSION 3.8)
project(alpha_msgs)
# some ROS 2 CMakeLists.txt template code
# find important dependencies
find_package(rclcpp REQUIRED)
find_package(rosidl_default_generators REQUIRED)
# find dependencies needed for your datatype
find_package(std_msgs REQUIRED)
# you can use this to get all msg files if you have many
set(MSGS_DIR "${CMAKE_CURRENT_SOURCE_DIR}/msg")
file(GLOB ALPHA_MSGS RELATIVE "${CMAKE_CURRENT_SOURCE_DIR}" "${MSGS_DIR}/*.msg")
# generate code for message types
rosidl_generate_interfaces(${PROJECT_NAME}
    ${ARUCO_MSGS}
    DEPENDENCIES std_msgs
# generate code for message types by manually
# specifying all the message types
# rosidl_generate_interfaces(${PROJECT_NAME}
#    msg/Alpha.msg
#    msg/AlphaArray.msg
#    DEPENDENCIES std_msgs
# rest of ROS 2 CMakeLists.txt template code
ament_export_dependencies(rosidl_default_runtime)
ament_package()
And your package.xml would usually include the following lines.
<depend>rclcpp</depend>
<depend>std_msgs</depend>
<depend>rosidl_default_generators</depend>
<depend>rosidl_default_runtime</depend>
<member_of_group>rosidl_interface_packages</member_of_group>
For more information, you can look at the px4_msgs GitHub repository. It has a lot of custom message examples.
I hope this helps. If I have made any mistakes or if you have any questions, let me know.
  • $\begingroup$ Thanks for the detail information. Yeah I have a configuration which is the reason for me to use the custom datatype in ROS2 message. I will figure out if there is something. Thanks. $\endgroup$
    – Rahul
    Commented Mar 22 at 12:30
  1. Create custom message(alpha.msg) with the data type as needed.
float32 alpha_message
  1. Create custom message(beta.msg) where you want to import
<package_name>/alpha beta_message
  • $\begingroup$ Please use code formatting , not block-quote formatting $\endgroup$ Commented Mar 20 at 19:29
