I'm trying to implement an extended Kalman filter to the accelerometer and gyroscope. However, the result is not good. It seems to have some errors in my codes. I check the equation and code again but I don't find the errors.
''' import serial import numpy as np import math import time
np.set_printoptions(precision=3, suppress=True)
class ExtendedKalmanFilter(object): def init(self, x0, P0, Q, R): # initialize vectors and matrices self.x0 = x0 self.P0 = P0 self.Q = Q self.R = R #self.dT = dT self.currentTimeStep = 0 self.estimates_aposteriori = [] self.estimates_aposteriori.append(x0) self.estimates_apriori = [] self.estimationErrorCovarianceMatricesAposteriori = [] self.estimationErrorCovarianceMatricesAposteriori.append(P0) self.estimationErrorCovarianceMatricesApriori = [] self.gainMatrices = [] self.errors = []
def stateSpaceContinuous(self, gyro_raw, x_k):
    transition_matrix = np.zeros(shape=(2, 3))
    transition_matrix[0, 0] = 1
    transition_matrix[0, 1] = np.sin(x_k[0, 0]) * np.tan(x_k[1, 0])
    transition_matrix[0, 2] = np.cos(x_k[0, 0]) * np.tan(x_k[1, 0])
    transition_matrix[1, 0] = 0
    transition_matrix[1, 1] = np.cos(x_k[0, 0])
    transition_matrix[1, 2] = -np.sin(x_k[0, 0])
    dxdt = np.matmul(transition_matrix, gyro_raw)
    return dxdt
def discreteTimeDynamics(self, gyro_raw, x_k, dT):
    x_kp1 = x_k + dT * self.stateSpaceContinuous(gyro_raw, x_k)
    return x_kp1
def jacobianStateEquation(self, gyro_raw, x):
    p = gyro_raw[0, 0]
    q = gyro_raw[1, 0]
    r = gyro_raw[2, 0]
    A = np.zeros(shape=(2, 2))
    A[0, 0] = q * np.cos(x[0, 0]) * np.tan(x[1, 0]) - r * np.sin(x[0, 0]) * np.tan(x[1, 0])
    A[0, 1] = (q * np.sin(x[0, 0]) * 1 / np.square(np.cos(x[1, 0]))) + (r * np.cos(x[0, 0]) * 1 / np.square(np.cos(x[1, 0])))
    A[1, 0] = -q * np.sin(x[0, 0]) - r * np.cos(x[0, 0])
    A[1, 1] = 0
    return A
def jacobianOutputEquation(self, x):
    C = np.zeros(shape=(2, 2))
    C[0, 0] = 0
    C[0, 1] = np.cos(x[1, 0])
    C[1, 0] = -np.cos(x[1, 0]) * np.cos(x[0, 0])
    C[1, 1] = np.sin(x[1, 0]) * np.sin(x[0, 0])
    #C[2, 0] = np.cos(x[1, 0]) * np.sin(x[0, 0])
    #C[2, 1] = np.sin(x[1, 0]) * np.cos(x[0, 0])
    return C
def outputEquation(self, x_k):
    return x_k
def propagateDynamics(self, gyro_raw, dt):
    # propagate the a posteriori estimate to compute the a priori estimate
    xk_minus = self.discreteTimeDynamics(gyro_raw, self.estimates_aposteriori[self.currentTimeStep], dt)
    #print("xk minus",xk_minus)
    # linearize the dynamics at the a posteriori estimate
    Akm1 = self.jacobianStateEquation(gyro_raw, self.estimates_aposteriori[self.currentTimeStep])
    #print("Akm1",Akm1.shape)
    # propagate the a posteriori covariance matrix in time to compute the a priori covariance
    Pk_minus = np.matmul(np.matmul(Akm1, self.estimationErrorCovarianceMatricesAposteriori[self.currentTimeStep]),
                         Akm1.T) + self.Q
    #print("Pk minus",Pk_minus.shape)
    # memorize the computed values and increment the time step
    self.estimates_apriori.append(xk_minus)
    self.estimationErrorCovarianceMatricesApriori.append(Pk_minus)
    self.currentTimeStep = self.currentTimeStep + 1
def computeAposterioriEstimate(self, currentMeasurement):
    currentMeasurement_angle = np.zeros(shape=(2, 1))
    currentMeasurement_angle[0,0] = math.atan(currentMeasurement[1,0] / math.sqrt(currentMeasurement[0,0]**2 + currentMeasurement[2,0]**2))
    currentMeasurement_angle[1,0] = -math.atan(currentMeasurement[0,0] / math.sqrt(currentMeasurement[1,0]**2 + currentMeasurement[2,0]**2))
    #print(currentMeasurement_angle.shape)
    # linearize the output equation at the a priori estimate for the time step k
    Ck = self.jacobianOutputEquation(self.estimates_apriori[self.currentTimeStep - 1])
    #print("Ck",Ck.shape)
    Smatrix = self.R + np.matmul(
        np.matmul(Ck, self.estimationErrorCovarianceMatricesApriori[self.currentTimeStep - 1]), Ck.T)
    #print("Smatrix",Smatrix.shape)
    # Kalman gain matrix
    Kk = np.matmul(self.estimationErrorCovarianceMatricesApriori[self.currentTimeStep - 1],
                   np.matmul(Ck.T, np.linalg.inv(Smatrix)))
    #print("Kk",Kk.shape)
    # update the estimate
    # prediction error
    sensor_model = np.zeros(shape=(2, 1))
    sensor_model[0,0] = np.sin(self.estimates_apriori[self.currentTimeStep - 1][1,0])
    sensor_model[1,0] = -np.cos(self.estimates_apriori[self.currentTimeStep - 1][1,0])*np.sin(self.estimates_apriori[self.currentTimeStep - 1][0,0])
    error_k = currentMeasurement_angle - sensor_model
    #error_k = currentMeasurement_angle - self.outputEquation(self.estimates_apriori[self.currentTimeStep - 1])
    #print("error k",error_k.shape)
    # a posteriori estimate
    #print('P danh gia',self.estimates_apriori[self.currentTimeStep - 1].shape)
    xk_plus = self.estimates_apriori[self.currentTimeStep - 1] + np.matmul(Kk, np.array([error_k])).reshape(2,1)
    #print('xk plus',xk_plus.shape)
    # update the covariance matrix
    # a posteriori covariance matrix update
    IminusKkC = np.eye(2,2)
    #print("Iminus",IminusKkC.shape)
    #print(np.matmul(self.R,Kk.T).shape)
    #Pk_plus = np.matmul(IminusKkC,np.matmul(self.estimationErrorCovarianceMatricesApriori[self.currentTimeStep - 1],
                                            #IminusKkC.T)) + np.matmul(Kk, np.matmul(self.R, Kk.T))
    Pk_plus = np.matmul((IminusKkC-np.matmul(Kk,Ck)),self.estimationErrorCovarianceMatricesApriori[self.currentTimeStep - 1])
    #print(Pk_plus.shape)
    # update the lists that store the vectors and matrices
    self.gainMatrices.append(Kk)
    # errors
    self.errors.append(error_k)
    # a posteriori estimates
    self.estimates_aposteriori.append(xk_plus)
    self.estimationErrorCovarianceMatricesAposteriori.append(Pk_plus)
Get the raw data
ser = serial.Serial('COM3', 115200, timeout=1)
acc = [] gyro = [] mag = [] old_time = time.time() ###############
x0 = np.array([np.pi/3, np.pi/3]).reshape(2, 1)
x0guess = np.zeros(shape=(2, 1)) x0guess[0] = x0[0] + 4 * np.random.randn() x0guess[1] = x0[1] + 4 * np.random.randn()
P0 = np.eye(2, 2) P0[0,0] = 0.1 P0[0,1] = 0 P0[1,0] = 0 P0[1,1] = 0.1
Q = np.eye(2, 2)
R = np.array([[1,0],[0,1]]).reshape(2,2)
KalmanFilterObject = ExtendedKalmanFilter(x0guess, P0, Q, R) i = 0 while True: data = ser.readline().decode("utf-8") dt = time.time() - old_time old_time = time.time() data = data[:-2] data = data.split(',') if data[0] == "$RAW": acc = np.array(data[1:4], dtype=float).reshape(3, 1) gyro = np.array(data[4:7], dtype=float).reshape(3, 1) mag = data[7:10] # phi, theta = prediction(initial_state_estimate, gyro, sensor_noise_w_k, dt, 0, 0) # print(phi, theta) #################################################################################
    KalmanFilterObject.propagateDynamics(gyro, dt)
    KalmanFilterObject.computeAposterioriEstimate(acc)
    print(KalmanFilterObject.estimates_aposteriori[-1]*(180/np.pi))
    #print("tien nghiem",KalmanFilterObject.estimates_apriori[-1])
    # i += 1
    # if i == 1000:
    #     break
  • $\begingroup$ Welcome to Robotics David, but I'm afraid that it is not clear what you are asking. We prefer practical, answerable questions, so it's a good idea to include details of what you want to achieve, what you tried, what you saw & what you expected to see. Please take a look at How to Ask & tour for more information on how stack exchange works and work through the Robotics question checklist to edit your question to make it clearer. $\endgroup$
    – Tully
    Commented Mar 20 at 6:05
