I am struggling with an example integration test for a ROS node (in Python). I have a node that somehow processes input data and outputs some messages based on this:
#!/usr/bin/env python3
import rospy
from image_utils import ImageUtils
from sensor_msgs.msg import Image
class TemplateNode:
    def __init__(self):
        rospy.init_node("template_node", anonymous=True)
        self.input_topic = rospy.get_param("~input_topic", "/input_topic")
        self.output_topic = rospy.get_param("~output_topic", "/output_topic")
        self.image_utils = ImageUtils()
        self.input_sub = rospy.Subscriber(self.input_topic, Image, self.input_callback)
        self.output_pub = rospy.Publisher(self.output_topic, String, queue_size=10)
    def input_callback(self, data):
        try:
            img_shape = self.image_utils.get_imgmsg_shape(data)
            result = str(img_shape)
            rospy.loginfo(result)
            self.publish_result(result)
        except Exception as e:
            rospy.logerr("Error processing image: {}".format(e))
    def publish_result(self, data):
        self.output_pub.publish(data)
    def run(self):
        rospy.spin()
if __name__ == "__main__":
    try:
        node = TemplateNode()
        node.run()
    except rospy.ROSInterruptException:
        pass
I created the following test for it:
import sys
import time
import unittest
import numpy as np
import rospy
from cv_bridge import CvBridge
PKG = "template_pkg"
NAME = "template_node_test"
PUB_TOPIC = "/input_topic"
SUB_TOPIC = "/output_topic"
TEST_NODE_NAME = "template_node"
class TemplateNodeTest(unittest.TestCase):
    def setUp(self):
        self.success = False
        self.callback_data = None
        self.bridge = CvBridge()
        self.img_data = np.random.randint(0, 255, (200, 100, 3), dtype=np.uint8)
        self.pub = rospy.Publisher(PUB_TOPIC, Image)
        rospy.init_node(NAME, anonymous=True)
    def callback(self, data):
        self.callback_data = data
        if data == str(self.img_data.shape):
            self.success = True
    def test_image_response(self):
        timeout_t = time.time() + 5.0
        while (
            not rostest.is_subscriber(
                rospy.resolve_name(PUB_TOPIC), rospy.resolve_name(TEST_NODE_NAME)
            and time.time() < timeout_t  # noqa: W503
            time.sleep(0.1)
        self.assert_(
            "%s is not up" % TEST_NODE_NAME,
        self.sub = rospy.Subscriber(SUB_TOPIC, String, self.callback)
        self.pub.publish(self.bridge.cv2_to_imgmsg(self.img_data, encoding="bgr8"))
        timeout_t = time.time() + 1.0
        while not rospy.is_shutdown() and not self.success and time.time() < timeout_t:
            time.sleep(0.1)
        self.assert_(self.success, "Wrong response: {}".format(self.callback_data))
    import rostest
    rostest.rosrun(PKG, NAME, TemplateNodeTest, sys.argv)
Launched using the following configuration:
<launch>
    <node name="template_node" pkg="template_pkg" type="template_node.py" output="screen" />
    <test test-name="template_node_test" pkg="template_pkg" type="template_node_test.py"/>
</launch>
It kinda works, but I the callback from the test is never called:
[INFO] [1710528976.836281]: (200, 100, 3)
[Testcase: testtemplate_node_test] ... ok
[ROSTEST]-----------------------------------------------------------------------
[template_pkg.rosunit-template_node_test/test_image_response][FAILURE]----------
False is not true : Wrong response: None
  File "/usr/lib/python3.8/unittest/case.py", line 60, in testPartExecutor
    yield
  File "/usr/lib/python3.8/unittest/case.py", line 676, in run
    self._callTestMethod(testMethod)
  File "/usr/lib/python3.8/unittest/case.py", line 633, in _callTestMethod
    method()
  File "/catkin_ws/src/template_pkg/test/template_node_test.py", line 65, in test_image_response
  File "/usr/lib/python3.8/unittest/case.py", line 1410, in deprecated_func
    return original_func(*args, **kwargs)
  File "/usr/lib/python3.8/unittest/case.py", line 765, in assertTrue
    raise self.failureException(msg)
I am confused, because I can see the node reporting the shape via logging:
Apparently, the message published by the node is not received by the test callback, I just do not understand why.
Would be grateful for any hint, including the test design, maybe I shall do it differently?
It turned to be out that there was not enough time to set up and start receiving messages before the publisher in my node starts sending messages. I fixed it by adding a delay between the subscription and publishing:
rospy.sleep(0.1)
