This question is almost similar to the other one which has the same issue of _launch.py was not found in the share package. What differs is i created the package using ament_cmake. So i created a urdf file for the robot and launch file attached below
from launch_ros.actions import Node
from launch.actions import ExecuteProcess
from ament_index_python.packages import get_package_share_directory
import os
    package_name = 'round_bot'
    pkg_share = get_package_share_directory(package_name)
    urdf_file_path = os.path.join(pkg_share, 'description', 'round_bot.urdf')
    with open(urdf_file_path, 'r') as urdf_file:
        robot_description = urdf_file.read()
    rviz_node = Node(
        package='rviz2',
        executable='rviz2',
        name='rviz2',
        output='screen'
    robot_state_publisher = Node(
        package='robot_state_publisher',
        executable='robot_state_publisher',
        name='robot_state_publisher',
        output='both',
        parameters=[{'robot_description': robot_description}],
    joint_state_publisher_gui = Node(
        package='joint_state_publisher_gui',
        executable='joint_state_publisher_gui',
        name='joint_state_publisher_gui'
    gazebo = ExecuteProcess(
        cmd=['gazebo', '--verbose'],
        output='screen'
    return LaunchDescription([
        rviz_node,
        robot_state_publisher,
        joint_state_publisher_gui,
        gazebo
i went through the ros2 wiki documentation, but i don't know why this issue heads up. Do i have to modify something in the CMakeLists.txt or package.xml file.
You'd have to install the launch directory into your install space - in your CMakeLists.txt file, you can add the following section :
install(
    DIRECTORY launch
    DESTINATION share/${PROJECT_NAME}
This would now copy over the entire launch directory over to the install space.
    $\begingroup$ Thanks for your response. It worked out. $\endgroup$
    – Vasanth
    Commented Mar 22 at 4:38
