i want to move to the package from any directory inside our terminal window
qrie@qrie-HP-Laptop-15-rb0xx:~/dev_ws$ colcon_cd two_wheeled_robot colcon_cd: command not found
    $\begingroup$ You did the setup as mentioned in the docs? $\endgroup$
    – aarsht7
    Commented Mar 11 at 9:10
Depending on how you installed colcon-cd, you need to source the colcon_cd.sh script before you can use the command. As an example, I installed colcon cd through apt, therefore my setup is:
apt install python3-colcon-cd
source /usr/share/colcon_cd/function/colcon_cd.sh
Following which colcon_cd works.
