I'm trying to increase the re-planning frequency of Nav2's A* global planner from 1 Hz to 10 Hz. In order to do this, I changed the expected_planner_frequency parameter from 1.0 to 10.0 in the planner_server section of nav2_params.yaml.
However, running ros2 topic hz on the global planner still shows a re-planning frequency of 1 Hz. Looking a little more into the code, it seems like changing expected_planner_frequency only affects whether a warning message will be displayed if the planner server is unable to compute a global path within 1/expected_planner_frequency seconds, and doesn't actually affect the global planner's re-planning frequency (i.e. the number of times it actually computes a path from start to goal each second).
As such, I wanted to ask how I can update the global planner's re-planning frequency. Is it a parameter I can set in nav2_params.yaml or do I need to modify the XML files that control Nav2's behavior tree? Any guidance would be appreciated, thanks.
Its in the behavior tree XML. The BT is where the navigation behavior is defined and customizable. The current default has a RateController over the planner to limit it to a fixed rate (1 hz), though you can use any other type of BT logic to define replanning events.
