Hello Robotics Community!
I'm trying to implement a ROS 2 topic to view the images from a camera I have added to the iRobot Create 3 simulation for classic Gazebo.
OS: ubuntu-desktop 22.04
ROS 2: Humble
Gazebo: classic 11 installed with apt
AWS small house world
I have the camera working in Gazebo, and in the Gazebo GUI I can see the projected image from the camera in the small house Gazebo world as the robot undocks and turns around. The projected image in Gazebo does look like what the camera should see.
Using libgazebo_ros_camera.so, I cannot see a ROS 2 topic (or images). I have followed this guide: https://github.com/ros-simulation/gazebo_ros_pkgs/wiki/ROS-2-Migration:-Camera
I cannot see any errors in the logs.
Here is the code I am using:
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" >
<joint name="camera_joint" type="fixed">
<parent link="base_link"/>
<child link="camera_link"/>
<origin xyz="0 0 0.2" rpy="0 0 0"/>
</joint>
<link name="camera_link">
<visual>
<geometry>
<box size="0.010 0.03 0.03"/>
</geometry>
<material name="red"/>
</visual>
</link>
<material name="red">
<color rgba="1 0 0 1"/>
</material>
<joint name="camera_optical_joint" type="fixed">
<parent link="camera_link"/>
<child link="camera_link_optical"/>
<origin xyz="0 0 0" rpy="${-pi/2} 0 ${-pi/2}"/>
</joint>
<link name="camera_link_optical"></link>
<gazebo reference="camera_link">
<sensor type="camera" name="camera1">
<pose> 0 0 0 0 0 0 </pose>
<always_on>1</always_on>
<visualize>1</visualize>
<update_rate>10</update_rate>
<camera name="head">
<horizontal_fov>1.089</horizontal_fov>
<image>
<format>R8G8B8</format>
<width>640</width>
<height>480</height>
</image>
<clip>
<near>0.05</near>
<far>8.0</far>
</clip>
</camera>
<plugin name="camera_controller" filename="libgazebo_ros_camera.so">
<ros>
<namespace>custom_ns</namespace>
<remapping>image_raw:=custom_img</remapping>
<remapping>camera_info:=custom_info</remapping>
</ros>
<camera_name>camera1</camera_name>
<frame_name>camera_link_optical</frame_name>
<hack_baseline>0.7</hack_baseline>
</plugin>
</sensor>
</gazebo>
</robot>
When I do a ros2 topic list
I do not see the custom_ns
namespace, or the camera-related topics.
I'd appreciate any help. Cheers!
custom_ns
used in ros tag of plugin. Shouldn't it be a string? $\endgroup$custom_ns
in this context is a string, not a variable. $\endgroup$
