I have very similar problem as in this question: ros2_control manage hardware_interface::return_type::ERROR
Basically, I use ROS2, Humble and wrote hardware interface for my controller. Everything works and I can read joint states, write motor commands.
But I wanted to write hardware interface, which might connect back if connection is lost.
So. I wrote on_configure like this:
hardware_interface::CallbackReturn DiffBotSystemHardware::on_configure(
  const rclcpp_lifecycle::State & /*previous_state*/)
  // BEGIN: This part here is for exemplary purposes - Please do not copy to your production code
  RCLCPP_INFO(rclcpp::get_logger("DiffBotSystemHardware"), "Configuring ...please wait...");
  RCLCPP_INFO(rclcpp::get_logger("DiffBotSystemHardware"), "Opening port ... %s", cfg_.device_name.c_str());
  int status = device_.Connect(cfg_.device_name);
  if (status != RQ_SUCCESS)
    RCLCPP_INFO(rclcpp::get_logger("DiffBotSystemHardware"), "Could not connect to controller," \
              " got status code: %d", status);
    return hardware_interface::CallbackReturn::ERROR;
  RCLCPP_INFO(rclcpp::get_logger("DiffBotSystemHardware"), "Successfully configured!");
  return hardware_interface::CallbackReturn::SUCCESS;
So, if it fails, it returns return hardware_interface::CallbackReturn::ERROR.
Ans I tried the same in read and write function - if communication is lost, it returns error.
As far as I understood, in this situation on_error function is called to handle this error and I guess it should as well change it state. https://control.ros.org/master/doc/ros2_control/hardware_interface/doc/hardware_components_userdoc.html
I expect and I want if on_configure functions returns return hardware_interface::CallbackReturn::ERROR, I expect that on_cleanup function is called and after some timeout on_configure is called again. So it tries to reconnect.
But in reality it does not call on_cleanup function. Should I do that somehow manually? Am I missing something? I checked examples, did not see solution.
And error output is as this if on_configure functions returns return hardware_interface::CallbackReturn::ERROR:
[ros2_control_node-1] Opening port: '/dev/ttyACM0'...failed.
[ros2_control_node-1] [INFO] [1709206199.569121295] [DiffBotSystemHardware]: Could not connect to controller, got status code: 1
[ros2_control_node-1] [INFO] [1709206199.569125271] [resource_manager]: Failed to 'configure' hardware 'DiffBot'
[ros2_control_node-1] [INFO] [1709206199.570563099] [controller_manager]: update rate is 10 Hz
[ros2_control_node-1] [INFO] [1709206199.570684613] [controller_manager]: RT kernel is recommended for better performance
[ros2_control_node-1] [WARN] [1709206199.570710731] [resource_manager]: (hardware 'DiffBot'): 'left_wheel_joint/velocity' command interface not in available list. This should not happen (hint: multiple cleanup calls).
[ros2_control_node-1] [WARN] [1709206199.570715183] [resource_manager]: (hardware 'DiffBot'): 'right_wheel_joint/velocity' command interface not in available list. This should not happen (hint: multiple cleanup calls).
[ros2_control_node-1] [WARN] [1709206199.570716868] [resource_manager]: (hardware 'DiffBot'): 'left_wheel_joint/position' state interface not in available list. This should not happen (hint: multiple cleanup calls).
[ros2_control_node-1] [WARN] [1709206199.570718409] [resource_manager]: (hardware 'DiffBot'): 'left_wheel_joint/velocity' state interface not in available list. This should not happen (hint: multiple cleanup calls).
[ros2_control_node-1] [WARN] [1709206199.570719804] [resource_manager]: (hardware 'DiffBot'): 'right_wheel_joint/position' state interface not in available list. This should not happen (hint: multiple cleanup calls).
[ros2_control_node-1] [WARN] [1709206199.570721317] [resource_manager]: (hardware 'DiffBot'): 'right_wheel_joint/velocity' state interface not in available list. This should not happen (hint: multiple cleanup calls).
This is a known limitation and got solved on rolling afaik. Could you please check if the code from this PR (should compile on humble) has a different behavior for you? If yes: It is not certain if we backport this to humble because it breaks ABI, but you can always compile ros2_control from source from the PR above even on humble. If no: please report an issue.
  • $\begingroup$ I compiled [github.com/ros-controls/ros2_control/pull/1422] this PR. But I could not launch it, not sure if is fully compatible with Humble. Although this PR [github.com/ros-controls/ros2_control/pull/838] was launched without any problems. But it did not solved this problem. It worked the same as I was using binary ros2_control packages. I tried humble branch from sources as well. Result is different, but still could not manage to make connection safe working. Anyway, thank you for helping out. I will continue to dig in. $\endgroup$
    – Hercogs
    Mar 1 at 9:58
  • $\begingroup$ 1422 itself should be fine, but probably we have to fix something with ros2_controller as well. your issue might be related to github.com/ros-controls/ros2_control/issues/1103, it was fixed but not backported to humble. $\endgroup$ Mar 1 at 12:07
