I have a robot system defined in an SDF with the following:
<sdf version='1.9'>
    <model name='simple_ddr' canonical_link='base_link'>
        <plugin filename="gz-sim-diff-drive-system" name="gz::sim::systems::DiffDrive">
            <left_joint>joint_wheelL</left_joint>
            <right_joint>joint_wheelR</right_joint>
            <wheel_separation>0.4</wheel_separation>
            <wheel_radius>0.1</wheel_radius>
            <odom_publish_frequency>0.1</odom_publish_frequency>
        </plugin>
        <plugin
            filename="gz-sim-sensors-system"
            name="gz::sim::systems::Sensors">
            <render_engine>ogre2</render_engine>
        </plugin>
        <link name='base_link'>
          <pose>0 0 0 0 0 0</pose>
            <inertial>
                <mass>1.0</mass>
                <inertia>
                    <ixx>0.011041666666666665</ixx>
                    <ixy>0.0</ixy>
                    <ixz>0.0</ixz>
                    <iyy>0.02604166666666667</iyy>
                    <iyz>0.0</iyz>
                    <izz>0.03541666666666667</izz>
                </inertia>
            </inertial>
            <collision name='base_link'>
              <geometry>
                <box>
                  <size>0.55 0.35 0.1</size>
                </box>
              </geometry>
            </collision>
            <visual name='base_link'>
              <geometry>
                <box>
                </box>
              </geometry>
              <material>
                  <ambient>0.0 0.6 0.6 1</ambient>
                  <diffuse>0.0 0.6 0.6 1</diffuse>
                  <specular>0.0 0.6 0.6 1</specular>
              </material>
            </visual>
            <sensor name="imu_sensor" type="imu">
                <always_on>1</always_on>
                <update_rate>1</update_rate>
                <visualize>true</visualize>
                <topic>imu</topic>
            </sensor>
            <sensor name='gpu_lidar' type='gpu_lidar'>"
                <pose relative_to='lidar_frame'>0 0 0 0 0 0</pose>
                <topic>lidar</topic>
                <update_rate>10</update_rate>
                <ray>
                    <scan>
                        <horizontal>
                            <samples>640</samples>
                            <resolution>0.01</resolution>
                            <min_angle>-1.396263</min_angle>
                            <max_angle>1.396263</max_angle>
                        </horizontal>
                        <vertical>
                            <samples>1</samples>
                            <min_angle>0</min_angle>
                            <max_angle>0</max_angle>
                        </vertical>
                    </scan>
                    <range>
                        <min>0.08</min>
                        <max>10.0</max>
                    </range>
                </ray>
                <visualize>1</visualize>
            </sensor>
        </link>
        <joint name='joint_wheelL' type='revolute'>
            <pose relative_to='base_link'>-0.2 -0.2 0.0 0 0 0</pose>
            <parent>base_link</parent>
            <child>wheelL</child>
            <axis>
            <xyz>0 1 0</xyz>
            <limit>
                <lower>-inf</lower>
                <upper>inf</upper>
            </limit>
            <dynamics>
                <damping>10</damping>
                <friction>1</friction>
                <spring_reference>0</spring_reference>
                <spring_stiffness>0</spring_stiffness>
            </dynamics>
            </axis>
        </joint>
        <link name='wheelL'>
            <pose relative_to='joint_wheelL'>0 0 0 0 0 0</pose>
            <inertial>
            <mass>0.050000000000000003</mass>
            <inertia>
                <ixx>0.001625000000000001</ixx>
                <ixy>0</ixy>
                <ixz>0</ixz>
                <iyy>0.00025000000000000011</iyy>
                <iyz>0</iyz>
                <izz>0.001625000000000001</izz>
            </inertia>
            </inertial>
            <collision name='wheelL_collision'>
            <pose>0 0 0 -1.5707963300000001 0 0</pose>
            <geometry>
                <cylinder>
                <length>0.050000000000000003</length>
                <radius>0.10000000000000001</radius>
                </cylinder>
            </geometry>
            </collision>
            <visual name='wheelL_visual'>
            <geometry>
                <cylinder>
                </cylinder>
            </geometry>
                <material>
                    <ambient>1.0 0.0 0.0 1</ambient>
                    <diffuse>1.0 0.0 0.0 1</diffuse>
                    <specular>1.0 0.0 0.0 1</specular>
                </material>
            </visual>
        </link>
        <joint name='joint_wheelR' type='revolute'>
            <pose relative_to='base_link'>-0.2 0.2 0.0 0 0 0</pose>
            <child>wheelR</child>
            <axis>
            <xyz>0 1 0</xyz>
            <limit>
                <lower>-inf</lower>
                <upper>inf</upper>
            </limit>
            <dynamics>
            </dynamics>
            </axis>
        </joint>
        <link name='wheelR'>
            <pose relative_to='joint_wheelR'>0 0 0 0 0 0</pose>
            <inertial>
            <inertia>
                <ixy>0</ixy>
                <ixz>0</ixz>
                <iyz>0</iyz>
            </inertia>
            </inertial>
            <collision name='wheelR_collision'>
            <geometry>
                <cylinder>
                </cylinder>
            </geometry>
            </collision>
            <visual name='wheelR_visual'>
            <geometry>
                <cylinder>
                </cylinder>
            </geometry>
                <material>
                </material>
            </visual>
        </link>
        <link name='caster'>
            <pose relative_to='joint_caster'>0 0 0.0 0 0 0</pose>
            <inertial>
                <mass>0.005</mass>
                <inertia>
                    <ixy>0</ixy>
                    <ixz>0</ixz>
                    <iyz>0</iyz>
                </inertia>
            </inertial>
            <collision name='caster_collision'>
                <geometry>
                    <sphere>
                        <radius>0.025</radius>
                    </sphere>
                </geometry>
                <surface>
                    <friction>
                        <ode>
                            <mu> 0.0 </mu>
                            <mu2> 0.0 </mu2>
                        </ode>
                    </friction>
                </surface>
            </collision>
            <visual name='caster_visual'>
                <geometry>
                    <sphere>
                    </sphere>
                </geometry>
            </visual>
        </link>
        <joint name='joint_caster' type='fixed'>
            <pose relative_to='base_link'>0.2 0 -0.075 0 0 0</pose>
            <child>caster</child>
        </joint>
        <frame name='joint_body' attached_to='base_link'>
        </frame>
        <frame name="lidar_frame" attached_to='base_link'>
            <pose>0.8 0 0.5 0 0 0</pose>
        </frame>
    </model>
</sdf>
I put everything into 2 launch files, a start_gazebo launch file and a spawn_robot launch file:
    pkg_robot_models = get_package_share_directory('robot_models')
    # Start gazebo
    world_file = os.path.join(pkg_robot_models, 'worlds', 'test_world.sdf')
    world_launch = IncludeLaunchDescription(
            PythonLaunchDescriptionSource([
                PathJoinSubstitution([
                    FindPackageShare('ros_gz_sim'),
                    'launch',
                    'gz_sim.launch.py'
            launch_arguments={
                'gz_args': world_file + ' -r -v 4'
            }.items()
    # Run the node
    return LaunchDescription([
        world_launch
    # Spawn robot system
    robot_filepath = os.path.join(pkg_robot_models, 'models', 'simple_DDR', 'model.sdf')
    ROBOT_MODEL = 'simple_DDR'
    start_gazebo_ros_spawner_cmd = Node(
        package='ros_gz_sim',
        executable='create',
        arguments=[
            '-name', ROBOT_MODEL ,
            '-file', robot_filepath,
            '-x', '0.0',
            '-y', '0.0',
            '-z', '0.3'
        output='screen',
    # Specify the name of the package and path to xacro file within the package
    os.environ["GAZEBO_MODEL_PATH"] = os.path.join(pkg_robot_models, "models", 'simple_DDR', 'model.sdf')
    os.environ["LIBGL_ALWAYS_SOFTWARE"] = "1"
    bridge_laser = Node(
            package='ros_gz_bridge',
            namespace='',
            executable='parameter_bridge',
            name='lidar',
            arguments=["/lidar/points@sensor_msgs/msg/LaserScan[gz.msgs.LaserScan", "--ros-args", "-r", "/lidar/points:=/laser_scan_cloud"]
    bridge_clock = Node(
            namespace='',
            name='lidar',
            arguments=["/clock@rosgraph_msgs/msg/Clock[gz.msgs.Clock"]
    bridge_tf = Node(
            namespace='',
            name='lidar',
            arguments=["/model/simple_DDR/tf@tf2_msgs/msg/TFMessage[gz.msgs.Pose_V"]
    bridge_odom = Node(
            namespace='',
            name='lidar',
            arguments=["/model/simple_DDR/odometry@nav_msgs/msg/Odometry[gz.msgs.Odometry"]
    # Run the node
        start_gazebo_ros_spawner_cmd,
        bridge_laser,
        bridge_clock,
        bridge_odom,
        bridge_tf
Result: communication does not work. Point cloud in RVIZ says Showing [0] messages of [0] received, no transform data or frame are sent, ...
Edit: Some additional information. ROS 2 Iron, Gazebo Harmonic, build of ros_gz was done with GZ_VERSION=harmonic
11
  • $\begingroup$ Are you getting data from the LiDAR at all? Echo it and verify. $\endgroup$
    – Nikolai
    Feb 27 at 10:33
  • $\begingroup$ @Nikolai when I do gz topic -e -t /lidar and gz topic -e -t /lidar/points I get messages $\endgroup$ Feb 27 at 11:06
  • $\begingroup$ OK, but what about the ROS topic? Are you receiving anything there? RVIZ listens to ros topics not gazebo topics $\endgroup$
    – Nikolai
    Feb 27 at 11:15
  • $\begingroup$ @Nikolai ROS topic receives nothing, that is the issue. I do ros2 topic echo /laser_scan_cloud $\endgroup$ Feb 27 at 11:23
  • $\begingroup$ Is there a reason why you built ros_gz from source instead of using the official binary (with apt)? also, you don't need to have many ros_gz_bridge, one is enough, and you can pass a yaml file containing all the bridge config. Finally, I see that the three bridge nodes have the same name, this might cause conflicts. Another thing you can check, is make sure that your ros_gz bridge executable links with the correct gz-harmonic libs (use ldd) $\endgroup$
    – ejalaa12
    Feb 27 at 13:22
Have you looked at this launch file? Might be something with how you run the bridge.
    $\begingroup$ I run it and works properly. I will take a look at the launch file and the sdf files associated and update in a comment to this answer with problem source. $\endgroup$ Feb 27 at 11:57
