I've recently started working on some localization algorithms like probabilistic road map and SLAM algorithms. What I'm looking for is a software that would help me in simulation for such algorithms. I started with pythons graphics.py and have now started working with Gazebo and ROS, but I've found it complex to use.
Is there any similar freeware simulation software that is easy to setup and work with, thus allowing me to reduce my time stressing over the simulation part and working more on the algorithms?
  • $\begingroup$ Check out the wiki page for simulator. $\endgroup$
    – Ben
    Oct 26, 2016 at 1:11
just use matlab or and python with a set of fixed features in space represented as points. Don't do any vision processing. At this point any vision processing would be overkill.
you are making this way too complex.
the measurements for your slam can be angles to features. create a set of 30 features randomly populating a 20m by 20m square. make your view point move in a circle around the square.
this is enough to get started with slam.
if you only rely on other people's packages and modules without going through the trouble of building your own you will never really get a sense of how these things work and break.
  • $\begingroup$ could you specify which python package would be most useful. $\endgroup$
    – badrobot15
    Oct 25, 2016 at 16:03
  • $\begingroup$ you would need numpy for some math $\endgroup$
    – AL-ROBOT
    Oct 25, 2016 at 21:15
  • $\begingroup$ I guess I'll start with the turtle package in python then $\endgroup$
    – badrobot15
    Oct 26, 2016 at 3:19
ZeroSim is built with Unity. It's not necessarily "easy" but arguably easier then Gazebo. Definitely creating and iterating environments in ZeroSim is much easier then Gazebo.
Disclosure: I am a ZeroSim developer.
