I am a new user of ros2 humble. I used rqt_image_view sometimes with ros2 run and since one day I see only the image placeholder and the panel for the topic and else is away. I don't know how I did this and I hope somebody can help me. I found the work around solution that I use rqt direct and add the image_view plugin.
enter image description here
  • Right click inside the image placeholder pane
  • Uncheck the 'Hide toolbar' checkbox
  • $\begingroup$ thank you 😍 I am so stupid 🥲😔 $\endgroup$ Mar 11 at 18:44
  • $\begingroup$ No problem. Glad to help! Make sure you accept this answer so that people with the same question can refer to this :) $\endgroup$
    – jc_sysu
    Mar 30 at 18:44
