I am willing to implement ros2_canopen with ros2_control. I am new to ros2_canopen.
I have four wheels robot (in simulation) and using diff_drive as ros2_control. Everthing is working fine but when I am trying to use ros2_canopen with ros2_control, I am getting error: "Waiting for '/controller_manager' node to exist".
Can someone guide me? ros2_canopen documentation is not friendly to understand things properly.
May be I am doing something wrong with the bus.yml, ros2_control.yaml and ros2_control.xacro.
bus.yml
options:
  dcf_path: "@BUS_CONFIG_PATH@"
master:
  node_id: 1
  driver: "ros2_canopen::MasterDriver"
  package: "canopen_master_driver"
  sync_period: 10000
defaults:
  dcf: "cia402_slave.eds"
  driver: "ros2_canopen::Cia402Driver"
  package: "canopen_402_driver"
  period: 10 # 1 ms
  heartbeat_producer: 1000 # Heartbeat every 1000 ms
  position_mode: 1 # Profile Position Mode
  sdo: # SDO executed during config
        - {index: 0x6081, sub_index: 0, value: 1000} # Set Profile Velocity
        - {index: 0x6083, sub_index: 0, value: 10000} # Set Profile Acceleration
        - {index: 0x6084, sub_index: 0, value: 10000} # Set Profile Deceleration
        - {index: 0x6085, sub_index: 0, value: 10000} # Set Quickstop Deceleration
        - {index: 0x6098, sub_index: 0, value: 0} # Set default Homing Method to 0 (No homing operation required)
        - {index: 0x60C2, sub_index: 1, value: 50} # Set Interpolation Time Period Value to 50 ms
        - {index: 0x60C2, sub_index: 2, value: -3} # Set Interpolation Time Index to 10-3s
  tpdo:
    1:
      enabled: true
      cob_id: "auto"
      transmission: 0x01
      mapping:
        - {index: 0x6041, sub_index: 0} # Statusword
        - {index: 0x6061, sub_index: 0} # Modes of Operation Display
    2:
      enabled: true
      cob_id: "auto"
      transmission: 0x01
      mapping:
        - {index: 0x6064, sub_index: 0} # Position Actual Value
        - {index: 0x606C, sub_index: 0} # Velocity Actual Value
    3:
      enabled: false
    4:
      enabled: false
  rpdo:
    1:
      enabled: true
      cob_id: "auto"
      mapping:
      - {index: 0x6040, sub_index: 0} # Controlword
      - {index: 0x6060, sub_index: 0} # Modes of Operation
    2:
      enabled: true
      cob_id: "auto"
      mapping:
      - {index: 0x607A, sub_index: 0} # Target Position
      - {index: 0x60FF, sub_index: 0} # Target Velocity
    3:
      enabled: false
    4:
      enabled: false
nodes:
  first_left_wheel_joint:
    node_id: 2
  first_right_wheel_joint:
    node_id: 3
  second_left_wheel_joint:
    node_id: 4
  second_right_wheel_joint:
    node_id: 5
diffbot_controllers.yaml
controller_manager:
  ros__parameters:
    update_rate: 10  # Hz
    joint_state_broadcaster:
      type: joint_state_broadcaster/JointStateBroadcaster
    diffbot_base_controller:
      type: diff_drive_controller/DiffDriveController
  ros__parameters:
    joints:
      left_wheel_names: ["first_left_wheel_joint", "second_left_wheel_joint"]
      right_wheel_names: ["first_right_wheel_joint", "second_right_wheel_joint"]
    command_interfaces:
      - position
    state_interfaces:
      - position
      - velocity
    wheel_separation: 0.4
    #wheels_per_side: 1  # actually 2, but both are controlled by 1 signal
    wheel_radius: 0.1
    wheel_separation_multiplier: 1.0
    left_wheel_radius_multiplier: 1.0
    right_wheel_radius_multiplier: 1.0
    publish_rate: 50.0
    odom_frame_id: odom
    base_frame_id: base_link
    pose_covariance_diagonal : [0.001, 0.001, 0.001, 0.001, 0.001, 0.01]
    twist_covariance_diagonal: [0.001, 0.001, 0.001, 0.001, 0.001, 0.01]
    open_loop: true
    enable_odom_tf: true
    cmd_vel_timeout: 0.5
    #publish_limited_velocity: true
    #velocity_rolling_window_size: 10
    # Velocity and acceleration limits
    # Whenever a min_* is unspecified, default to -max_*
    linear.x.has_velocity_limits: true
    linear.x.has_acceleration_limits: true
    linear.x.has_jerk_limits: false
    linear.x.max_velocity: 1.0
    linear.x.min_velocity: -1.0
    linear.x.max_acceleration: 1.0
    linear.x.max_jerk: 0.0
    linear.x.min_jerk: 0.0
    angular.z.has_velocity_limits: true
    angular.z.has_acceleration_limits: true
    angular.z.has_jerk_limits: false
    angular.z.max_velocity: 1.0
    angular.z.min_velocity: -1.0
    angular.z.max_acceleration: 1.0
    angular.z.min_acceleration: -1.0
    angular.z.max_jerk: 0.0
    angular.z.min_jerk: 0.0
diffbot.ros2_control.xacro
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro">
  <xacro:macro name="diffbot_ros2_control" params="name
    use_mock_hardware
    prefix
    bus_config
    master_config
    can_interface_name
    master_bin
    <ros2_control name="${name}" type="system">
      <xacro:unless value="${use_mock_hardware}">
        <hardware>
          <plugin>canopen_ros2_control/RobotSystem</plugin>
          <param name="bus_config">${bus_config}</param>
          <param name="master_config">${master_config}</param>
          <param name="can_interface_name">${can_interface_name}</param>
          <param name="master_bin">"${master_bin}"</param>
          <param name="example_param_hw_start_duration_sec">0</param>
          <param name="example_param_hw_stop_duration_sec">3.0</param>
        </hardware>
      </xacro:unless>
      <xacro:if value="${use_mock_hardware}">
        <hardware>
          <plugin>mock_components/GenericSystem</plugin>
          <param name="calculate_dynamics">true</param>
        </hardware>
      </xacro:if>
      <joint name="${prefix}first_left_wheel_joint">
        <param name="device_name">first_left_wheel_joint</param>
        <command_interface name="velocity"/>
        <state_interface name="position"/>
        <state_interface name="velocity"/>
      </joint>
      <joint name="${prefix}first_right_wheel_joint">
        <param name="device_name">first_right_wheel_joint</param>
      </joint>
      <joint name="${prefix}second_left_wheel_joint">
        <param name="device_name">second_left_wheel_joint</param>
      </joint>
      <joint name="${prefix}second_right_wheel_joint">
        <param name="device_name">second_right_wheel_joint</param>
      </joint>
    </ros2_control>
  </xacro:macro>
</robot>
diffbot.urdf
<!-- Basic differential drive mobile base -->
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="diffdrive_robot">
  <xacro:arg name="prefix" default="" />
  <xacro:arg name="use_mock_hardware" default="false" />
  <xacro:include filename="diffbot_description.urdf.xacro" />
  <!-- Import Rviz colors -->
  <xacro:include filename="diffbot.materials.xacro" />
  <xacro:arg name="can_interface_name" default="vcan0" />
  <!-- Import diffbot ros2_control description -->
  <xacro:include filename="diffbot.ros2_control.xacro" />
  <xacro:diffbot prefix="$(arg prefix)" />
  <xacro:diffbot_ros2_control
    name="DiffBot" prefix="$(arg prefix)" use_mock_hardware="$(arg use_mock_hardware)"
    bus_config="$(find panda_canopen)/config/cia402/bus.yml"
    master_config="$(find panda_canopen)/config/cia402/master.dcf"
    can_interface_name="$(arg can_interface_name)"
    master_bin=""
</robot>
launch
from launch.actions import DeclareLaunchArgument, RegisterEventHandler, OpaqueFunction, IncludeLaunchDescription
from launch.conditions import IfCondition
from launch.event_handlers import OnProcessExit
from launch.substitutions import Command, FindExecutable, PathJoinSubstitution, LaunchConfiguration
from launch_ros.actions import Node
from launch_ros.substitutions import FindPackageShare
from launch.launch_description_sources import PythonLaunchDescriptionSource
import yaml
def launch_setup(context, *args, **kwargs):
    can_interface_name = LaunchConfiguration("can_interface_name")
    nodes_to_start = []
    # Launch slaves nodes
    slave_launch = PathJoinSubstitution(
        [FindPackageShare("canopen_fake_slaves"), "launch", "cia402_slave.launch.py"]
    bus_config = PathJoinSubstitution(
        [FindPackageShare("my_robot"), "config", "cia402", "bus.yml"]
    with open(bus_config.perform(context), 'r') as f:
        bus_config_dict = yaml.safe_load(f)
    joints = []
    for key in bus_config_dict.keys():
        if "joint" in key:
            joints.append(key)
    for joint in joints:
        nodes_to_start.append(
            IncludeLaunchDescription(
                PythonLaunchDescriptionSource(slave_launch),
                launch_arguments={
                    "node_id": str(bus_config_dict[joint]["node_id"]),
                    "node_name": f"slave_node_{joint}",
                    "slave_config": PathJoinSubstitution([
                         FindPackageShare("my_robot"), "config", "cia402", str(bus_config_dict[joint]["dcf"])
                    "can_interface_name": can_interface_name,
                }.items(),
    # Launch master node
    master_launch = PathJoinSubstitution(
        [FindPackageShare("canopen_core"), "launch", "canopen.launch.py"]
    master_config = PathJoinSubstitution(
        [FindPackageShare("my_robot"), "config", "cia402", "master.dcf"]
            PythonLaunchDescriptionSource(master_launch),
            launch_arguments={
                "master_config": master_config,
                "master_bin": "",
                "bus_config": bus_config,
            }.items(),
    return nodes_to_start
    # Declare arguments
    declared_arguments = []
    declared_arguments.append(
        DeclareLaunchArgument(
            "gui",
            default_value="true",
            description="Start RViz2 automatically with this launch file.",
            "use_mock_hardware",
            default_value="false",
            description="Start robot with mock hardware mirroring command to its states.",
    # Initialize Arguments
    gui = LaunchConfiguration("gui")
    use_mock_hardware = LaunchConfiguration("use_mock_hardware")
    # Get URDF via xacro
    robot_description_content = Command(
            PathJoinSubstitution([FindExecutable(name="xacro")]),
                [FindPackageShare("my_robot"), "urdf", "diff_robot.urdf"]
            "use_mock_hardware:=",
            use_mock_hardware,
    robot_description = {"robot_description": robot_description_content}
    robot_controllers = PathJoinSubstitution(
            "config",
            "diffbot_controllers.yaml",
    rviz_config_file = PathJoinSubstitution(
        [FindPackageShare("my_robot"), "diffbot/rviz", "diffbot.rviz"]
    control_node = Node(
        package="controller_manager",
        executable="ros2_control_node",
        parameters=[robot_description, robot_controllers],
        output="both",
    robot_state_pub_node = Node(
        package="robot_state_publisher",
        executable="robot_state_publisher",
        output="both",
        parameters=[robot_description],
        remappings=[
            ("/diff_drive_controller/cmd_vel_unstamped", "/cmd_vel"),
    rviz_node = Node(
        package="rviz2",
        executable="rviz2",
        name="rviz2",
        output="log",
        arguments=["-d", rviz_config_file],
        condition=IfCondition(gui),
    joint_state_broadcaster_spawner = Node(
        executable="spawner",
        arguments=["joint_state_broadcaster", "--controller-manager", "/controller_manager"],
    robot_controller_spawner = Node(
        arguments=["diffbot_base_controller", "--controller-manager", "/controller_manager"],
    # Delay rviz start after `joint_state_broadcaster`
    delay_rviz_after_joint_state_broadcaster_spawner = RegisterEventHandler(
        event_handler=OnProcessExit(
            target_action=joint_state_broadcaster_spawner,
            on_exit=[rviz_node],
    # Delay start of robot_controller after `joint_state_broadcaster`
    delay_robot_controller_spawner_after_joint_state_broadcaster_spawner = RegisterEventHandler(
            on_exit=[robot_controller_spawner],
    nodes = [
        control_node,
        robot_state_pub_node,
        delay_rviz_after_joint_state_broadcaster_spawner,
        delay_robot_controller_spawner_after_joint_state_broadcaster_spawner,
            "can_interface_name",
            default_value="vcan0",
            description="CAN interface name to run the master and, when in simulation, the fake slaves.",
    return LaunchDescription(declared_arguments + nodes + [OpaqueFunction(function=launch_setup)])
Sorry for the late response. To use it with real hardware you have to do the following:
  1. remove fake_slaves nodes from your launch file, you don't have to replace them with other real nodes.
        [FindPackageShare("canopen_fake_slaves"), "launch", "cia402_slave.launch.py"])
  2. Setup CAN controller like in the Setup page
    sudo modprobe gs_usb
    sudo ip link set can0 up type can bitrate 500000
    sudo ip link set can0 txqueuelen 1000
    sudo ip link set up can0
  3. Change "vcan0" to "can0" anywhere in the code if it's written manually like this one
    if it's passed as an argument in the launch file you can run the launch file and add the argument
    ros2 launch <pkg_name> <launch_file_name> can_interface_name:="can0"
After launching the file use these service calls, for me they work with this order and I don't know any other way to start it, it should start automatically when you launch the file but for me, it doesn't and I have to call these services for each joint:
/joint_name/nmt_start_node
/joint_name/init
/joint_name/velocity_mode
To make the robot move publish on /cmd_vel since you are using diff_drive
10
  • $\begingroup$ Thank you for your reply! Do you have any idea, how to publish data using topic with the same setup of ros2_control and ros2_canopen? Because when we are using real hardware, it is not efficient to command the drive or communicate with drive using service. $\endgroup$
    – whiz
    Apr 16 at 13:37
  • $\begingroup$ I have created a repository on GitHub as an example so you can use it. link To send data you can publish to the /cmd_vel topic as you do to move a diff_bot I have written some steps to accomplish that. $\endgroup$ Apr 17 at 9:35
  • $\begingroup$ Thank you for your quick response and github repo! Related to publish over topic, I mean to say using /tpdo and /rpdo. $\endgroup$
    – whiz
    Apr 17 at 13:47
  • $\begingroup$ I have git clone your repository, but when call services as per README. I am having these following result. :~$ ros2 service call /left_wheel_joint/init std_srvs/srv/Trigger requester: making request: std_srvs.srv.Trigger_Request() response: std_srvs.srv.Trigger_Response(success=False, message='') :~$ ros2 service call /left_wheel_joint/velocity_mode std_srvs/srv/Trigger waiting for service to become available... requester: making request: std_srvs.srv.Trigger_Request() response: std_srvs.srv.Trigger_Response(success=False, message='') $\endgroup$
    – whiz
    Apr 24 at 15:32
  • $\begingroup$ you have to call the services in this order 1- /nmt_start_node 2- /init 3- /velocity_mode Note: I am using ROS Iron and I have built the master branch in ros2_canopen because humble branch didn't include velocity mode $\endgroup$ Apr 28 at 8:02
If you can share the full error that will help more. Second, you have
bus.yml
it would help if you changed it to
velocity_mode: 1 # Profile velocity Mode
the same with the command interface should be velocity not position in
command_interfaces:
  - velocity
these changes may not fix your error but these are the correct settings for the diffbot.
  • $\begingroup$ Thank you! It helped! As I am using simulation right now. Do you have idea how can I implement the same things on real hardware.? $\endgroup$
    – whiz
    Mar 11 at 6:06
