ToF (time-of-flight) cameras seem susceptible to bright outdoor conditions.
Are there any sensors made for bright outdoor conditions and could be embeddable in a robot that could detect and/or track small objects (5cm - 25cm) with a range of 10m - 100m?
Would radar work?
12
  • $\begingroup$ Define challenging light conditions. Too dark, too bright, both of them rapidly changing. $\endgroup$ Oct 15 '16 at 13:46
  • $\begingroup$ @BenceKaulics too bright. thanks for the question. $\endgroup$
    – Crashalot
    Oct 15 '16 at 18:10
  • $\begingroup$ 5cm object tracking at 100m? i wouldn't be surprised if that was itar territory $\endgroup$
    – holmeski
    Oct 18 '16 at 18:35
  • $\begingroup$ @holmeski hmmm really? what if the speed at that distance wasn't very high? this is to track a golf ball. any suggestions on how to do this (beyond computer vision)? $\endgroup$
    – Crashalot
    Oct 18 '16 at 18:39
  • $\begingroup$ Can you modify tracked objects, i.e put some transmitter in it? What is reading frequency that you would need? Do you need only azimuth, or distance also? $\endgroup$
    – mactro
    Oct 19 '16 at 9:24
Tracking small objects is always tricky.
You can use Ultrasonic sound sensors. Calibrate it to the distance you want to detect. They have low range though.
If you can work on a more complex model then computer vision could also help (Highly unreliable- It needs to have a very strong filter algorithm)
  • $\begingroup$ Thanks for the answer! What about radar? $\endgroup$
    – Crashalot
    Oct 18 '16 at 18:27
