I have a doubt regarding the use of Robot_localization.
I was watching this tutorial: https://navigation.ros.org/tutorials/docs/navigation2_with_gps.html
in my case I have a real robot (equipped with imu, gps, and wheel encoders) with which I already publish a transformation between the base_link frame of my robot and the odom frame.
I've seen that the many examples around (like the tutorial above) use 2 ekf nodes, the first to compute the local odom--base_link transformation, and a second to compute the global map-odom transformation.
But if I already have the odom--base_link transformation existing and therefore the odom frame already exists, is it always necessary for me to create the two ekf nodes?
or can I just create the global node ekf?
Thanks everyone in advance
If a node already does the transform between base_link to odom, then you do not need to have two instances of robot_localization. You just configure one instance of EKF to provide the transform between map and odom.
