I am building a model (of a cable) and a controller in simulink to actuate the end points of the cable in simulink. Since matlab is a numerical simulator and it lacks physics based interactions with the environment, I am thinking to use Gazebo for it (water interactions). I want to close the loop and do realtime co-simulation.
I saw matlab documentation for it - https://nl.mathworks.com/help/robotics/ug/perform-co-simulation-between-simulink-and-gazebo.html
I do not understand the step to perform - packageGazeboPlugin Please let me know how to do it.
What do you mean by "the step to perform - packageGazeboPlugin"?
This is a function in Robotics System Toolbox (RST), if you have this toolbox installed, you can run this command directly in MATLAB Command Window:
>> packageGazeboPlugin
Please feel free to reach out to MathWorks Technical Support team if you need further assistant.
    $\begingroup$ Thanks, I was confused with the step. Reaching out to the technical support helped me :) $\endgroup$
    – vbalaji21
    Feb 29 at 17:05
