I tried a few things but I am not so knowlegable about it. I tried with cmakeLists.txt:
cmake_minimum_required(VERSION 3.5)
project(wpitest)
set(CMAKE_CXX_STANDARD 14)
set(CMAKE_VERBOSE_MAKEFILE ON)
# Include headers
include_directories(.)
#here
link_directories(wiringPi)
#target_include_directories(${PROJECT_NAME} wiringPi)
for the blink.cpp file :
#include <iostream>
#include <wiringPi.h>
// LED Pin - wiringPi pin 0 is BCM_GPIO 17.
#define LED 4
int main ()
  while (1)
      printf ("Raspberry Pi blink\n") ;
wiringPiSetupGpio();
  pinMode (LED, OUTPUT) ;
    digitalWrite (LED, HIGH) ;  // On
    delay (50) ;        // mS
    digitalWrite (LED, LOW) ;   // Off
    delay (50) ;
  return 0 ;
Check the lib installed sudo apt-get install wiringpi
And try find_library and target_link_libraries
*If you use rpi4, build from github source maybe required.
  • $\begingroup$ yeah that worked thank you $\endgroup$ Commented Feb 17 at 13:24
