I am new in ROS2 and robotics development with an automotive engineer - electrical background.
As I am a doing a project that requires ROS2 for integration of automated features.
I want to confirm this information as I haven't seen any source to particularly answer this (or I just being dumb)
So the moment I have finished organizing my package (with different nodes communicating via DDS), so that I would have a framework. How do I then integrate the hardware (with actuators (could use arduino for controlling) and a LiDAR) into this framework for controlling?
I have done some small research on how is this done and from there what I know and understand is:
  • I have to create a customize hardware interface to communicate with ROS2
  • Utilize the ros2_control package to communicate to the framework.
I want to ask if are these two methods above is correct, and if im not please correct me!
I appreciate all your help!
If real-time capability is an issue for you, then I suggest using ros2_control for your actuators and sensors (encoders, odometry etc). For lidars there are other driver packages out there, normally you don't need this information within ros2_control but at a higher level for mapping/navigation etc.
  • $\begingroup$ Thank you for the answer! $\endgroup$
    – Duy Nguyen
    Commented Feb 14 at 11:17
