I would like to use and test this type of servo motor, significantly stronger than the ones I've been using previously.
However the datasheets seem to be limited and I can't exactly tell how to use the driver.
  1. Would it be fair to assume that to use this system, I would get say a 500 W (or higher) power supply and be able to plug into my (North American) wall outlet to use this motor? And if so, would that give me enough power? I believe NA wall outlets give something like 12 A @110 V max, or 1.32 kW.
  2. How could I tell if this is enough for the above servo, or might I have to upgrade to using an industrial power line?
  3. What if I want to power multiple of these motors at the same time? Surely 1 power outlet wouldn't work.
  4. [semi-related bonus question] What is the difference between "2 phase", "3 phase" etc in this stepper/servo motor?
  • 3
    $\begingroup$ I'll caution you against buying this. At a minimum, if you're insistent on buying it, contact the vendor and get everything clear. I'll point out the typical eBay scam - you may not be buying everything in the picture. To be explicitly clear, the title says "motor driver kit*. It does NOT say "motor kit". For shipping to the US at least, the shipping cost is almost the cost of the part, and Return Policy rule 4 says, "Return shipping is to be paid by the buyer." So, you can return it for any reason within 14 days, but your net refund is the base $355 on nearly 842 spent. $\endgroup$
    – Chuck
    Oct 12, 2016 at 20:59
  • $\begingroup$ Check the schematic on the page - the motor doesn't have a part number. Only the driver does. The post may be advertising what kind of motor is compatible with the driver they're selling. It's not clear. Again - ask everything in advance before you buy. $\endgroup$
    – Chuck
    Oct 12, 2016 at 21:03
  • $\begingroup$ Absolutely, I was able to obtain a datasheet of the motor from the supplier with basic dimensions and torque/speed curves. It's risky but the reward is high too. $\endgroup$
    – JDS
    Oct 13, 2016 at 5:03
  • $\begingroup$ Also: I'm fairly certain it's motor + driver. Because the package weight is 21KG and motor weight is 19KG or so. Alibaba/express is very forgiving to foreign buyers with a history, I've been refunded before for products not received (including shipping fees). $\endgroup$
    – JDS
    Oct 13, 2016 at 5:09
  1. No. If there is no {installation, electrical, maintenance, etc} manual/description etc. (and maybe add also quality certificate also here) it is not fair to assume anything. Buying something without knowing its characteristics and placing it under current is a fire hazard, therefore it is not safe to assume characteristics! Guessing characteristics form picures is never a good idea.
  2. From the (missing) installation manual.
  3. If a motor consumes 500 W then 1 electrical outlet capable of supplying 1,32 kW can power 2 motors. 2 Electrical outlets capable of supplying 1,32 kW can power 2 each.
  4. phases are the number of "inputs" for a motor. a 3 phase motor needs 3 signals to turn (dephased from each other) a two phase motor need two. The number of phases times the number of poles give the number of steps which divided 1 rotation (if I am not mistaking).
  • $\begingroup$ Ah alright so phases has to do with the default step angle it seems? Are there advantages of 2 vs. 3 phase systems other than that? And I'll try to follow up with datasheet information for the product. $\endgroup$
    – JDS
    Oct 13, 2016 at 5:05
  • 2
    $\begingroup$ 2 adjacent electrical outlets will likely be on the same 15A breaker circuit so the conclusion in point 3 may not be valid. $\endgroup$
    – Octopus
    Oct 13, 2016 at 5:49
