i have created a workspace in ros2 humble in Ubuntu 22.04 and i am trying to spawn the robot in gazebo empty world using the following command:
ros2 run gazebo_ros launch spawn_entity.py -topic robot_description -entity bot_name
but i am getting the following error:
No executable found
i tried sourcing my workspace using source install/setup.bash but it didn't work
  • $\begingroup$ @ssarkar - you should probably post that as an answer $\endgroup$ Commented Feb 15 at 0:25
spawn_entity is a node, and not a launch file. If you remove the launch word from your command, it should be working fine.
So, the command should look like the following:
ros2 run gazebo_ros spawn_entity.py -topic robot_description -entity bot_name
