I installed Ros2 Humble on Ubuntu 22.04. When I launch the command ros2 I get the following error message
Traceback (most recent call last): File "/opt/ros/humble/bin/ros2", line 33, in sys.exit(load_entry_point('ros2cli==0.18.8', 'console_scripts', 'ros2')())
File "/opt/ros/humble/bin/ros2", line 22, in importlib_load_entry_point for entry_point in distribution(dist_name).entry_points
File "/usr/lib/python3.10/importlib/metadata/init.py", line 969, in distribution return Distribution.from_name(distribution_name)
File "/usr/lib/python3.10/importlib/metadata/init.py", line 548, in from_name raise PackageNotFoundError(name)
importlib.metadata.PackageNotFoundError: No package metadata was found for ros2cli
Do you have any ideas on how to solve this issue?
  • $\begingroup$ You seem to be missing ros2cli. $\endgroup$ Feb 15 at 0:26
  • $\begingroup$ For more help please edit your question to include what packages you've installed and how. As well as how you've setup your system. $\endgroup$
    – Tully
    Feb 29 at 20:53
This can happen if the PYTHONPATH hasn't been set right. For example, perhaps you explicitly set the PYTHONPATH in a non-additive way after running the setup.bash for ROS.
