I'm trying to understand how I can possibly get the global position of a model in a Gazebo simulation through ROS2.
I've seen that Gazebo publishes data to the /world/<world_name>/pose/info topic via messages of type gz.msgs.Pose_V. Following this, I created a bridge to ROS2 via ros_gz_bridge:
ros2 run ros_gz_bridge parameter_bridge /world/world_demo/dynamic_pose/info@tf2_msgs/msg/TFMessage[gz.msgs.Pose_V
(I got the corresponding ROS2 message from the ros_gz_bridge README Unfortunately, the "translation" is incomplete and in the messages received in ROS2 there's no indication of the entity each portion refers to. enter image description here
Am I missing something here? Is there a way to accomplish this at the moment?
I'm using:
ROS2 humble
Gazebo Garden
ok, in the end that was the right way, but the wrong tool.
To publish global positions the right plugin to use is the OdometryPublisher (docs). It works more or less the same way as the PosePublisher, apart from the published messages of course.
ORIGINAL ANSWER
Found the solution after struggling some more... Scratch that, this publishes
the transform of its child entities
as per docs...
I don't know about the seemingly incomplete conversion of the /world/<world_name>/pose/info topic, but I've found out that to get a model position in the world you need to add the PosePublisher plugin to the model.
<?xml version="1.0"?>
<sdf version="1.6">
    <model name="quadcopter">
        <pose>0 0 0 0 0 0</pose>
        <link name="base">
            <pose frame="">0 0 0 0 0 0</pose>
        </link>
        <plugin
            filename="gz-sim-pose-publisher-system"
            name="gz::sim::systems::PosePublisher">
            <publish_link_pose>true</publish_link_pose>
            <publish_collision_pose>false</publish_collision_pose>
            <publish_visual_pose>false</publish_visual_pose>
            <publish_nested_model_pose>false</publish_nested_model_pose>
        </plugin>
    </model>
</sdf>
This will enable a /model/<model_name>/pose topic that you can then bridge to ROS2 via ros_gz_bridge.
