I am currently working on a project that involves using pymoveit2 in a ROS 2 environment, and I'm in need of assistance regarding documentation and installation steps.
Project Overview:
  • I am working on a project in which I want to calculate the inverse kinematics to obtain the joint position of the robot. Since I'm using Python, I've identified pymoveit2 as a potential solution. However, I encountered an issue during the installation.
Challenges Faced:
  • When attempting to install moveitpy2 using the command pip install pymoveit2, I encountered the following error:
Defaulting to user installation because normal site-packages is not writeable ERROR: Could not find a version that satisfies the requirement pymoveit2 (from versions: none) ERROR: No matching distribution found for pymoveit2
If there are specific steps or dependencies I need to address during installation, your guidance would be highly appreciated.
Request for Documentation:
  • Kindly point me to any available documentation or tutorials for pymoveit2.
Environment Information:
  • ROS Version: ROS2 Humble
  • OS: Ubuntu 22.04
  • Python Version: 3.10.12
I appreciate any guidance, links to documentation, or insights you can provide. Thank you in advance for your support!
