Video player gives "could not demultiplex stream"
import cv2
import math
import numpy as np
import pyrealsense2 as rs
from ultralytics import YOLO
# Configure depth and color streams
pipeline = rs.pipeline()
config = rs.config()
config.enable_stream(rs.stream.color, 640, 480, rs.format.bgr8, 30)
pipeline.start(config)
# Define video writer for detection results
fourcc = cv2.VideoWriter_fourcc(*'XVID')
out_detection = cv2.VideoWriter('detection_5.avi', fourcc, 30, (608, 480))
# Define video writer for normal video stream
out_normal = cv2.VideoWriter('normal_video_5.avi', fourcc, 30, (608,480))
# Load YOLO model
model = YOLO("/home/rushabh/Railway_bot/weights/best.pt")
# Object classes
classNames = ["car","bus", "auto"]
try:
while True:
# Wait for a coherent pair of frames: depth and color
frames = pipeline.wait_for_frames()
color_frame = frames.get_color_frame()
if not color_frame:
continue
# Convert images to numpy arrays
color_image = np.asanyarray(color_frame.get_data())
# Perform object detection
results = model(color_image, stream=True)
# Process detection results
for r in results:
boxes = r.boxes
for box in boxes:
# Extract bounding box coordinates
x1, y1, x2, y2 = box.xyxy[0]
x1, y1, x2, y2 = int(x1), int(y1), int(x2), int(y2) # Convert to int values
# Draw bounding box
cv2.rectangle(color_image, (x1, y1), (x2, y2), (0, 255, 0), 3)
# Extract confidence and class name
confidence = math.ceil((box.conf[0] * 100)) / 100
cls = int(box.cls[0])
# Draw class name
org = [x1, y1]
font = cv2.FONT_HERSHEY_SIMPLEX
fontScale = 1
color = (255, 0, 0)
thickness = 2
cv2.putText(color_image, classNames[cls], org, font, fontScale, color, thickness)
# Write the frame with detections to the detection video file
# out_detection.write(color_image)
cv2.imshow('RealSense with Detection', color_image)
if cv2.waitKey(1) == ord('q'):
break
finally:
# Stop streaming
pipeline.stop()
# Release resources
out_detection.release()
cv2.destroyAllWindows()
