I'm building ros2 humble from source, I would like to change the default DDS to rmw_cyclonedds_cpp
, so with my self built version of ROS2, the user does not have to specify RMW_IMPLEMENTATION
and use rmw_cyclonedds_cpp
as default.
What source change do I need to or to set some environment variable during ROS2 source building?
I have read this, but did not find the answer for my need.
https://docs.ros.org/en/humble/How-To-Guides/Working-with-multiple-RMW-implementations.html
