I've tried to launch my saved world file. However it kept showing
Resource not found: The following package was not found in : ros1_wiki ROS path [0]=/opt/ros/noetic/share/ros ROS path [1]=/home/rvl224/brian2lee/gazebo/forklift_test/src ROS path [2]=/opt/ros/noetic/share The traceback for the exception was written to the log file
I can launched all the urdf model in the launch file an empty world, but the walls and sdf models in the saved world can't. I've catkin make and run . devel/setup.bash before I roslaunch the launch file. Down below is my launch file and the file location of "test.world" (the saved world file)
/home/rvl224/brian2lee/gazebo/forklift_test/src/ros1_wiki/world/test.world
<?xml version="1.0"?>
<launch>
    <param name="robot_description" command="xacro '$(find forklift)/urdf/forklift.urdf.xacro'"/>
    <param name="pallet_description" command="xacro '$(find forklift)/urdf/pallet.urdf.xacro'"/>
    <node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher"/>
    <node name="joint_state_publisher_gui" pkg="joint_state_publisher_gui" type="joint_state_publisher_gui"/>
    <include file="$(find gazebo_ros)/launch/empty_world.launch">
        <arg name="world_name" value="$(find ros1_wiki)/world/test.world"/>
        <arg name="paused" value="false"/>
        <arg name="use_sim_time" value="true"/>
        <arg name="gui" value="true"/>
        <arg name="headless" value="false"/>
        <arg name="debug" value="false"/>
    </include>
    <node name="spawning_forklift" pkg="gazebo_ros" type="spawn_model"
          args="-urdf -model forklift -param robot_description -x -2 -y 0 -z 0 -Y 0"/>
    <node name="spawning_pallet" pkg="gazebo_ros" type="spawn_model"
          args="-urdf -model pallet -param pallet_description -x 0 -y 0 -z 0"/>
</launch>
edit: The CmakeList under ros1_wiki
# toplevel CMakeLists.txt for a catkin workspace
# catkin/cmake/toplevel.cmake
cmake_minimum_required(VERSION 3.0.2)
project(Project)
set(CATKIN_TOPLEVEL TRUE)
# search for catkin within the workspace
set(_cmd "catkin_find_pkg" "catkin" "${CMAKE_SOURCE_DIR}")
execute_process(COMMAND ${_cmd}
  RESULT_VARIABLE _res
  OUTPUT_VARIABLE _out
  ERROR_VARIABLE _err
  OUTPUT_STRIP_TRAILING_WHITESPACE
  ERROR_STRIP_TRAILING_WHITESPACE
if(NOT _res EQUAL 0 AND NOT _res EQUAL 2)
  # searching fot catkin resulted in an error
  string(REPLACE ";" " " _cmd_str "${_cmd}")
  message(FATAL_ERROR "Search for 'catkin' in workspace failed (${_cmd_str}): ${_err}")
endif()
# include catkin from workspace or via find_package()
if(_res EQUAL 0)
  set(catkin_EXTRAS_DIR "${CMAKE_SOURCE_DIR}/${_out}/cmake")
  # include all.cmake without add_subdirectory to let it operate in same scope
  include(${catkin_EXTRAS_DIR}/all.cmake NO_POLICY_SCOPE)
  add_subdirectory("${_out}")
else()
  # use either CMAKE_PREFIX_PATH explicitly passed to CMake as a command line argument
  # or CMAKE_PREFIX_PATH from the environment
  if(NOT DEFINED CMAKE_PREFIX_PATH)
    if(NOT "$ENV{CMAKE_PREFIX_PATH}" STREQUAL "")
      if(NOT WIN32)
        string(REPLACE ":" ";" CMAKE_PREFIX_PATH $ENV{CMAKE_PREFIX_PATH})
      else()
        set(CMAKE_PREFIX_PATH $ENV{CMAKE_PREFIX_PATH})
      endif()
    endif()
  endif()
  # list of catkin workspaces
  set(catkin_search_path "")
  foreach(path ${CMAKE_PREFIX_PATH})
    if(EXISTS "${path}/.catkin")
      list(FIND catkin_search_path ${path} _index)
      if(_index EQUAL -1)
        list(APPEND catkin_search_path ${path})
      endif()
    endif()
  endforeach()
  # search for catkin in all workspaces
  set(CATKIN_TOPLEVEL_FIND_PACKAGE TRUE)
  find_package(catkin QUIET
    NO_POLICY_SCOPE
    PATHS ${catkin_search_path}
    NO_DEFAULT_PATH NO_CMAKE_FIND_ROOT_PATH)
  unset(CATKIN_TOPLEVEL_FIND_PACKAGE)
  if(NOT catkin_FOUND)
    message(FATAL_ERROR "find_package(catkin) failed. catkin was neither found in the workspace nor in the CMAKE_PREFIX_PATH. One reason may be that no ROS setup.sh was sourced before.")
  endif()
endif()
catkin_workspace()
Can you upload your CMakeLists.txt from folder ros1_wiki? Maybe the name of the package is not correct. Also, did you make a catkin_make?
  • $\begingroup$ I added the cmakelist content above. Yes I did make a catkin_make. If I tried to run the launch file without the <arg name="world_name" value="$(find ros1_wiki)/world/test.world"/> it'll run normally (Just without the walls and sdf file saved in the .world file which I wanted, only the urdf models in launch file). And I double checked and straight up pasted the package name from folder name, so I don't think that will be the issue. $\endgroup$
    – brian2lee
    Feb 1 at 19:32
  • $\begingroup$ Can you change the line 6 in the CMake to project(ros1_wiki) and try again? $\endgroup$
    – rdelgadov
    Feb 1 at 19:48
  • $\begingroup$ no it does not work, still the same error (sry not replying cuz kinda busy for the past week) $\endgroup$
    – brian2lee
    Feb 7 at 14:35
