I am working on an autonomous robot that needs nav_msgs/Odometry to work with ros navigation stack
nav_msgs/Odometry
std_msgs/Header header
  uint32 seq
  time stamp
  string frame_id
string child_frame_id
geometry_msgs/PoseWithCovariance pose
  geometry_msgs/Pose pose
    geometry_msgs/Point position
      float64 x
      float64 y
      float64 z
    geometry_msgs/Quaternion orientation
      float64 x
      float64 y
      float64 z
      float64 w
  float64[36] covariance
geometry_msgs/TwistWithCovariance twist
  geometry_msgs/Twist twist
    geometry_msgs/Vector3 linear
      float64 x
      float64 y
      float64 z
    geometry_msgs/Vector3 angular
      float64 x
      float64 y
      float64 z
and I have motor 2 motor encoders that publish ticks as the motor rotates and an IMU which pubish data as sensor_msgs/Imu
  uint32 seq
  time stamp
  string frame_id
  float64 x
  float64 y
  float64 z
  float64 w
float64[9] orientation_covariance
geometry_msgs/Vector3 angular_velocity
  float64 x
  float64 y
  float64 z
float64[9] angular_velocity_covariance
geometry_msgs/Vector3 linear_acceleration
  float64 x
  float64 y
  float64 z
float64[9] linear_acceleration_covariance
how odometry data generated from these sensors or if I add more localization sensors like GPS and Magnetometer than these two sensors how I can fuse them to get Odom data that are compatiable with ros navigation stack
That data may be fused in the robot localization module.
http://docs.ros.org/en/noetic/api/robot_localization/html/index.html
