When I launch AMCL and give initial pose , the amcl launched terminal shows:
Failed to transform initial pose in time (Lookup would require extrapolation into the future. Requested time 1706706126.307448 but the latest data is at time 601.061000, when looking up transform from frame [odom] to frame [base_footprint])
Also When I try to move to bot using teleop, the laser_scan data also moves !!!
RViz: Message Filter dropping message: frame ‘laser_frame’ at time 601.844 for reason ‘the timestamp on the message is earlier than all the data in the transform cache’
My workspace : GitHub - Vinothhk/2W_Diff_Bot
  • $\begingroup$ I'm observing similar behavior. Did you figure it out? $\endgroup$ Commented Apr 24 at 11:29
  • $\begingroup$ Yes I solved it. In my case the problem is in urdf. The orientation of lidar should be in the direction of orientation of body of the robot $\endgroup$
    – Vinoth
    Commented Apr 26 at 1:45
