I recently created a fresh virtual machine of Ubuntu 22.04 with UTM.
I installed Ignition Fortress and ROS Humble with the following command: sudo apt-get install ros-humble-ros-gz.
I then sourced the ros setup script with source /opt/ros/humble/setup.zsh in my zsh terminal.
I am following this tutorial and can run ign gazebo which opens gazebo. But ros2 returns ros2: command not found. What am I missing?
After sourcing the setup script, I am also missing environment variables such as $ROS_DISTRO. I checked this by running printenv | grep -i ROS.
