I am trying to run the ros2_control_demo_example_7
package of ros2_control_demos with some modifications to spawn r6bot
robot inside gazebo. I am not using gazebo_ros2_control
plugin since on using it I am getting error as pointed out here. As suggested there, I am using ros2_control_node
in place of gazebo_ros2_control
plugin.
I have also included the physical properties of each joint in the urdf:
<dynamics damping="0.15" friction="0"/>
Also, defined the material properties of each link in the gazebo description as below:
<gazebo reference="${prefix}base_link">
<selfCollide>true</selfCollide>
<mu1 value="0.0"/>
<mu2 value="0.0"/>
<kp value="10000000.0"/>
<kd value="1.0"/>
<turnGravityOff>false</turnGravityOff>
</gazebo>
Everything seems to be working in the terminal but I am getting below output in the gazebo:
r6bot_controller.launch.py
gaz_pkg_share = FindPackageShare(package='ros2_control_demo_example_7').find('ros2_control_demo_example_7')
world_file_name = 'empty.world'
world_path = os.path.join(gaz_pkg_share, 'worlds', world_file_name)
# Set the path to the SDF model files.
gazebo_models_path = os.path.join(gaz_pkg_share, 'models')
if 'GAZEBO_MODEL_PATH' in os.environ:
os.environ['GAZEBO_MODEL_PATH'] = os.environ['GAZEBO_MODEL_PATH'] + ':' + gazebo_models_path
else:
os.environ['GAZEBO_MODEL_PATH'] = gazebo_models_path
# Get URDF via xacro
robot_description_content = Command(
PathJoinSubstitution([FindExecutable(name="xacro")]),
FindPackageShare("ros2_control_demo_example_7"),
"urdf",
"r6bot.urdf.xacro",
robot_description = {"robot_description": robot_description_content}
robot_controllers = PathJoinSubstitution(
"config",
"r6bot_controller.yaml",
rviz_config_file = PathJoinSubstitution(
[FindPackageShare("ros2_control_demo_description"), "r6bot/rviz", "view_robot.rviz"]
gazebo = IncludeLaunchDescription(
PythonLaunchDescriptionSource(
[PathJoinSubstitution([FindPackageShare("gazebo_ros"), "launch", "gazebo.launch.py"])]
launch_arguments={"verbose": "true",
"paused":"false",
"gui":"true",
"world":world_path,
"headless":"false",
"use_sim_time":"true"}.items(),
spawn_entity = Node(
package="gazebo_ros",
executable="spawn_entity.py",
arguments=["-topic", "robot_description", "-entity", "r6bot"],
output="screen",
control_node = Node(
package="controller_manager",
executable="ros2_control_node",
parameters=[robot_description, robot_controllers],
remappings=[
"/forward_position_controller/commands",
"/position_commands",
output="both",
joint_state_publisher_node = Node(
package="joint_state_publisher_gui",
executable="joint_state_publisher_gui",
condition=IfCondition("true"),
robot_state_pub_node = Node(
package="robot_state_publisher",
executable="robot_state_publisher",
output="both",
parameters=[robot_description],
rviz_node = Node(
package="rviz2",
executable="rviz2",
name="rviz2",
output="log",
arguments=["-d", rviz_config_file],
joint_state_broadcaster_spawner = Node(
executable="spawner",
arguments=["joint_state_broadcaster", "--controller-manager", "/controller_manager"],
robot_controller_spawner = Node(
arguments=["r6bot_controller", "-c", "/controller_manager"],
# Delay rviz start after `joint_state_broadcaster`
delay_rviz_after_joint_state_broadcaster_spawner = RegisterEventHandler(
event_handler=OnProcessExit(
target_action=joint_state_broadcaster_spawner,
on_exit=[rviz_node],
# Delay start of robot_controller after `joint_state_broadcaster`
delay_robot_controller_spawner_after_joint_state_broadcaster_spawner = RegisterEventHandler(
on_exit=[robot_controller_spawner],
nodes = [
joint_state_publisher_node,
control_node,
robot_state_pub_node,
gazebo,
spawn_entity,
delay_rviz_after_joint_state_broadcaster_spawner,
delay_robot_controller_spawner_after_joint_state_broadcaster_spawner,
return LaunchDescription(nodes)
controller_manager:
ros__parameters:
update_rate: 10 # Hz
joint_state_broadcaster:
type: joint_state_broadcaster/JointStateBroadcaster
r6bot_controller:
type: ros2_control_demo_example_7/RobotController
forward_position_controller:
type: forward_command_controller/ForwardCommandController
ros__parameters:
joints:
- joint_1
- joint_2
- joint_3
- joint_4
- joint_5
- joint_6
interface_name: position
r6bot_controller:
ros__parameters:
joints:
- joint_1
- joint_2
- joint_3
- joint_4
- joint_5
- joint_6
command_interfaces:
- position
state_interfaces:
- position
ros2 control
(Here I am using ros2_control_demo_example_8/RRBotTransmissionsSystemPositionOnlyHardware
plugin, defined in the ros2_control_demo_example_8 package)
<ros2_control name="${name}" type="system">
<hardware>
<plugin>ros2_control_demo_example_8/RRBotTransmissionsSystemPositionOnlyHardware</plugin>
<param name="actuator_slowdown">100.0</param>
</hardware>
<joint name="joint_1">
<command_interface name="position">
<param name="min">{-2*pi}</param>
<param name="max">{2*pi}</param>
</command_interface>
<state_interface name="position">
<param name="initial_value">0.0</param>
</state_interface>
</joint>
<joint name="joint_2">
</state_interface>
</joint>
<joint name="joint_3">
<param name="min">{-pi}</param>
<param name="max">{pi}</param>
</state_interface>
</joint>
<joint name="joint_4">
</state_interface>
</joint>
<joint name="joint_5">
</state_interface>
</joint>
<joint name="joint_6">
</state_interface>
</joint>
<transmission name="transmission1">
<plugin>transmission_interface/SimpleTransmission</plugin>
<actuator name="actuator1" role="actuator1"/>
<joint name="joint_1" role="joint_1">
<mechanical_reduction>4.0</mechanical_reduction>
<offset>0.0</offset>
</joint>
</transmission>
<transmission name="transmission2">
<actuator name="actuator2" role="actuator2"/>
<joint name="joint_2" role="joint_2">
</joint>
</transmission>
<transmission name="transmission3">
<actuator name="actuator3" role="actuator3"/>
<joint name="joint_3" role="joint_3">
</joint>
</transmission>
<transmission name="transmission4">
<actuator name="actuator4" role="actuator4"/>
<joint name="joint_4" role="joint_4">
</joint>
</transmission>
<transmission name="transmission5">
<actuator name="actuator5" role="actuator5"/>
<joint name="joint_5" role="joint_5">
</joint>
</transmission>
<transmission name="transmission6">
<actuator name="actuator6" role="actuator6"/>
<joint name="joint_6" role="joint_6">
</joint>
</transmission>
</ros2_control>
I am expecting robotic arm to spawn inside gazebo with below configuration:
Am I missing something or doing something wrong? Is this happening because of PID or other parameters? I would really appreciate some advice on this.
