I am working on autonomous vehicle control, i used the kinematic bicycle model,
  • For the speed reference I used a speed profile not a constant speed(given below [![speed][1]][1]
  • for the steering angle I used the radius to generate the steering angle d=atan(L/r), you will find the code used below. where did i go wrong so that i don't have any pursuit ?
  • the results of the (x,y) vehicle position (in blue) and the road (in red) are given by [![result][2]][2]
  • Code:
`roadCenters = [114.0758 129.2616 -0.002332852; 123.7942 132.6021 -0.002582644; 133.8967 137.3962 -0.002888271; 137.0677 138.9055 -0.00298834; 150.6001 145.0092 -0.003429421; 173.4132 160.0353 -0.004368632; 285.7534 229.03 -0.01051842; 395.1082 301.1 -0.01935268; 454.6491 327.2592 -0.02460683; 461.2142 328.7133 -0.02515263; 471.513 329.7459 -0.02595824; 496.1926 330.8792 -0.02788709; 526.3301 325.9428 -0.030045; 555.0835 315.8794 -0.03197174; 626.267 278.9304 -0.03682783; 785.6708 195.2591 -0.05133038; 806.3408 188.8024 -0.05371195; 839.4267 183.6897 -0.0578257; 867.7778 186.2227 -0.06168913; 896.191 191.5745 -0.06577247; 967.1287 218.0381 -0.07697441; 1008.957 234.3338 -0.08402597; 1039.905 250.1733 -0.08959433; 1055.937 261.9383 -0.09269901; 1060.51 267.1768 -0.09367474; 1075.818 284.7013 -0.09699582; 1093.205 314.3776 -0.1013468; 1105.474 343.11 -0.1049445];
x=roadCenters(:,1); y=roadCenters(:,2);
nPoints = size(roadCenters, 1);
theta = [0:0.1:2*pi, 0];
nCurves = nPoints - 2; gridSize = ceil(sqrt(nCurves));
plotRow = 1; plotCol = 1; figure(1) clf; for currentPt = 1:nCurves x0 = x(currentPt + 0); x1 = x(currentPt + 1); x2 = x(currentPt + 2);
y0 = y(currentPt + 0); y1 = y(currentPt + 1); y2 = y(currentPt + 2);
A = [2*(x1-x0) , 2*(y1-y0); ... 2*(x2-x0) , 2*(y2-y0)];
B = [((x1^2 - x0^2) + (y1^2 - y0^2)); ... ((x2^2 - x0^2) + (y2^2 - y0^2))]; X = (A^(-1))*B; xc = X(1); yc = X(2);
r = sqrt((x0 - xc)^2 + (y0 - yc)^2); d=atan(L/r); disp(d) circle_x = rcos(theta); circle_y = rsin(theta);
subplot(gridSize, gridSize, currentPt) plot([x0, x1, x2], [y0, y1, y2], 'LineWidth', 1, 'Color', [0 0 0]); hold on; plot([x0, x1, x2], [y0, y1, y2], 'x', 'LineWidth', 1, 'Color', [1 0 0]); plot(circle_x + xc, circle_y + yc, 'LineStyle', '-.', 'LineWidth', 0.5, 'Color', [0 0 0.8]); axis equal title(['Curvature at point ', num2str(currentPt)]); end t = (0:length(d)-1); % Create a time vector D= timeseries(d, t); % Create a timeseries object `
It's not exactly clear what you're looking for help with here because you seem to be asking two distinctly different questions in the same post:
  1. How do I convert a polyline into a steering angle, and
  2. How do I make the lateral control independent of speed?
For the first question, I would try to convert the polyline into a radius of curvature, and then convert the radius of curvature to a steering angle via Ackermann geometry (assuming it's an Ackermann-steered vehicle).
Assuming the vehicle starts at a point in the polyline, transform the next two points into vehicle coordinates, then fit a circle to those points. This will give you the radius of curvature. Then you can calculate the steering angle as
$$\mbox{atan}\left(\frac{L}{r}\right)$$
where $L$ is the wheel base (distance between front and rear axles) and $r$ is the radius of curvature.
For the question of making it independent of speed, what you're really saying is that you want to remove time as a factor, which is totally doable. Instead of having a PID response curve that plots reference and feedback versus time, you could use longitudinal position.
Instead of calculating PID terms with respect to time, try:
proportional_error = ref - fbk;
integral_error = integral_error + (proportional_error * dX);
derivative_error = (proportional_error - prev_proportional_error) / dX;
prev_proportional_error = proportional_error;
Finally, if this were me, I would use the calculated steering angle as a "feed-forward" term that does the bulk of the steering work as a proactive control term, and then supplement that with the result of a PID control that's wrapped around the lane offset value as a reactive control term, like:
y_ref = 0; // Assuming 0 is the center of the lane
y_fbk = // lane position feedback from some sensor
desired_steering_angle = // calculated from polyline and vehicle geometry
dX = // new forward vehicle motion since last loop update
proportional_error = y_ref - y_fbk;
kP = // Proportional gain, this is a parameter you tune
kI = // Integral gain,
kD = // Derivative gain
pid_output = (kP * proportional_error) + (kI * integral_error) + (kD * derivative_error);
steering_command = desired_steering_angle + pid_output;
and this should be something that performs consistently across a large variety of lane curvatures and vehicle speeds.
:EDIT:
Based on the update to your question, it looks like you're putting the entire x/y points array into the curvature equation, but I think you need to go point by point and reevaluate. In looking at the results here, you also have a pretty hard "knee" in the data where you go [0,0] to [2.8249,0] and then from there to [-34.4, 35.2]. You'll need to break up the path into smaller parts to get a smooth trajectory.
Here's some code that iterates across the points:
roadCenters = [0      0 0; ...
               2.8249 0 0; ...
               -34.4 35.2 0; ...
               -145 -57 0; ...
               -148 -211 0; ...
               -41 -326 0; ...
               165 -400 0; ...
               417 -425 0; ...
               950 -32 0; ...
               1034 111 0];
x=roadCenters(:,1);
y=roadCenters(:,2);
plotRow = 1;
plotCol = 1;
figure(1)
clf;
  X = (A^(-1))*B;
  xc = X(1);
  yc = X(2);
  circle_x = r*cos(theta);
  circle_y = r*sin(theta);
  hold on;
  axis equal
end
And that gives this set of plots:
Plot of curvatures
You can see that knee in the first plot, and then also pay attention to the units here - the first plot has axes scaled in the tens and later plots are scaled in the thousands.
5
  • $\begingroup$ thank you very much for your help, and what i mean by the speed independent from the steering angle, when calculating the steering angle at several attempts it would not give me a path pursuit so i thought , the problem may be with my speed reference but since you made it clear can you please explain to me more about how to convert the polyline into a radius of curvature, because i tried this formula and i am sure its the curvature i got wrong. $\endgroup$
    – Asmaa GZ
    Feb 13 at 9:57
  • $\begingroup$ @AsmaaGZ you said you tried it and you're sure the curvature is wrong; can you please edit your question to show what you tried and the answer you got? $\endgroup$
    – Chuck
    Feb 13 at 19:27
  • $\begingroup$ thank you again for your help, I have have added the code and the results $\endgroup$
    – Asmaa GZ
    Feb 15 at 11:49
  • $\begingroup$ @AsmaaGZ I updated the answer, please see if this is helpful. $\endgroup$
    – Chuck
    Feb 16 at 17:43
  • $\begingroup$ your code was really helpful, I added some code lines to calculate the steering angle at each radius so that i get a path pursuit and i also modified the road into a better one ( you could see that in the edited question where i put the new result along with my program), now i am not sure where is the problem and why my bicycle model isn't following the road. $\endgroup$
    – Asmaa GZ
    Feb 19 at 13:06
