I want to know if the Create 2 can interface a laser radar? For example an RPLidar.
closed as unclear what you're asking by Bence Kaulics, 50k4, Mark Booth♦ Oct 11 '16 at 12:43
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
$\begingroup$ Open both of the datasheets and check the interfaces. $\endgroup$ – Bence Kaulics Oct 6 '16 at 15:50
$\begingroup$ I don't have a create2 now, so i don't have datasheets. but i want to buy a create2. at first i have to know if the create2 can add Lidar? are there someone could tell the answer to me ? $\endgroup$ – John Lau Oct 6 '16 at 16:13
1$\begingroup$ You dont have to buy one to find its datasheet on the internet. $\endgroup$ – Bence Kaulics Oct 6 '16 at 17:59
If you are willing to work at it, adding LIDAR to the Create 2 should be possible. If you read the iRobot Create 2 OI Specs, you will see that you can communicate with the Create via serial communication. If you look at the datasheet for the RPLidar, you will see that you can communicate with the sensor using serial communication. Because you cannot program the Create directly, you will need to use a microcontroller to interface the LIDAR and the robot.
