When using ROS Noetic (ROS2 answer great though too) with the Pilz industrial planner, I noticed that the plan output trajectory has 100ms between samples. I searched the web (and the source-code) but couldn't figure out where this 100ms comes from. Is there a parameter to adjust it or is it hard-coded somewhere?
I didn't see a parameter for the other planners (CHOMP, STOMP, ...) either. I get that post-processing can "fill-in" these trajectories, but I'm curious how to increase the planner output density instead.
The pilz source-code has a "plan(...)" function that takes a sampling rate, which seems to be called by a "generate(...)" function which also takes a sampling rate, but I couldn't figure out what calls the "generate(...)" function.
Extra tags: frequency, duration, sampling rate, sample rate, hz, publish rate,
  • $\begingroup$ Hi! Have you had a look at the parameter server to see if you can find anything related to the sampling time of the planner? Just a hint, as I am not very experienced with trajectory planners... $\endgroup$
    – Luca
    Commented Feb 23 at 14:38
+50
In case of ROS2
Moveit2 planners inherit the planning_interface::PlanningContext and planning_interface::PlannerManager classes as shown here.
When a planning problem has to be solved then the the planning_interface::PlanningContext::solve method of the PlanningContextof the planner is called.
In case of the pilz planner the pilz_industrial_motion_planner::PlanningContextBase inherits from planning_interface::PlanningContext and pilz_industrial_motion_planner::CommandPlanner inherits from planning_interface::PlannerManager.
The solve method of pilz_industrial_motion_planner::PlanningContextBase directly calls the generate method of a pilz_industrial_motion_planner::TrajectoryController which then calls its own pilz_industrial_motion_planner::TrajectoryController plan method (Note, the plan method is virtual in the TrajectoryGenerator class and only implemented in the TrajectoryGenerator{PTP|LIN|CIRC} classes respectively).
Depending on the used motion planning strategy of pilz (e.g. point-to-point motion, linear trajectory or circular trajectory) the generator then plans the motion.
In summary, a simplified call stack looks like this (types are left out and names shortened):
PlanningContext::solve(res)
↓ is implemented by pilz
PlanningContextBase::solve(res)
↓ calls
TrajectoryGenerator::generate(scene, req, res, sampling_time=0.1)
↓ calls
TrajectoryGenerator::plan(scene, req, plan_info, sampling_time, joint_trajectory)
where res is a reference to the motion plan response, scene is the planning scene of the context, req is the motion planning request of the context, sampling_time is the sampling rate of your question and plan_info is a pilz collection of some scene and req information.
Note, that the sampling_time parameter is introduced in the TrajectoryGenerator::generate method with a default value of 0.1 (the 100ms you mentioned) and is directly forwarded to the call of TrajectoryGenerator::plan but not changed (not even in the point-to-point, linear nor circular trajectory generators calls of the TrajectoryGenerator::generate method - the default value of 100ms of the parameter is used) nor read from anywhere like a ros parameter. Thus the value appears truly hardcoded in ROS2.
The implementation of moveit for ROS1 is different - so it still might be possible there.
include/pilz_industrial_motion_planner/trajectory_generator.h:
       planning_interface::MotionPlanResponse& res, double sampling_time = 0.1);
https://github.com/ros-planning/moveit/blob/87148afb11c33d73c35a586ef3330d2d1fa7ba56/moveit_planners/pilz_industrial_motion_planner/include/pilz_industrial_motion_planner/trajectory_generator.h#L109
Found with
cd pilz_industrial_motion_planner
grep -r "0.1"
