I have an issue with communication between:
  • Ubuntu 22.04 container running on a Ubuntu 20.04 PC
  • Raspberry Pi running 22.04
Both are running Humble.
Essentially, communication works fine between both devices for a short period of time (couple minutes, haven't tested the exact duration). After then, only each device's local nodes, publishers, subscribers, action servers, etc. are visible. Notably, if a node is already latched to a topic on another device it will continue to receive messages. But if I stop and restart that node after a couple minutes of the container running (such as the demo_nodes_cpp listener) it will not long receive any messages.
I am currently using Cyclone DDS, although I was using Fast before and it showed the same behavior. The container was ran with the following flags: -it -d --net=host --pid=host
Here is everything I've tested:
  • ros2 multicast send/receive (works both initially and later - never had any issues)
  • ros2 run demo_nodes_cpp talker/listener (only works if started in the first couple minutes)
  • Various of my own nodes, action server/clients, etc. All only are able to latch onto topics/actions servers for the first couple minutes
  • Stopping and starting the container fixes the problem temporarily (I get another couple minutes...)
Does anyone have any insight into how I could address this issue?
