Gazebo Sim 6.15 (Fortress), ROS 2 Iron.
I want to get "ground truth" robot position into ROS, so that I could use it to validate diff_drive odometry (combining it with IMU to detect wheel slip maybe etc.). Presumably as also Odometry frames so that I could write my own script to compare them and calculate drift or sth.
I have found references to some "p3d" plugin, but only from around 2015 and before, so presumably they apply to Gazebo Classic. Gazebo Sim website has a checkmark next to "JointStatePublisher" plugin, but I have utterly failed to find any information about it, and any search is littered with results about the ROS plugin with same name and Gazebo Classic :(.
What is the standard approach for eg comparing simulated wheel odometry with actual position in simulation?
  • $\begingroup$ Haven't tried in ros2 yet, but in ros1 it was published on a topic: rostopic echo /gazebo/model_states $\endgroup$ Jan 22 at 17:01
