I am working with C++ for a Teensy (Arduino-like board). There is a pattern that I have a lot which annoys me because it is tedious and ugly. But I don't know how to refactor it to make it less repetitive and prettier. Here's the code (in simplified form)
void Arm::armCommand(String command, float arg)
    if (command == "wrist")
        wrist((int)arg);
    if (command == "elbow")
        elbow((int)arg);
    if (command == "shoulder")
        shoulder((int)arg);
  • $\begingroup$ if your code works without error, then it belongs at codereview.stackexchange.com $\endgroup$
    – jsotola
    Jan 21 at 16:52
  • $\begingroup$ they may not know teensy c++ but sure ok. $\endgroup$
    – pitosalas
    Jan 21 at 17:23
Here's something that looks like it might be the direction you want to go: https://stackoverflow.com/questions/19473313/how-to-call-a-function-by-its-name-stdstring-in-c.
In summary, create a map between the string name and the function pointer, but here I'm assuming Teensy supports function pointers.
I had the same doubt on this.
Here is how I solved this doubt: https://github.com/ConradLiuuu/strategy-sample-cpp/blob/master/include/cart.hpp
In master branch, I wrote the code like you.
In refactor branch, I wrote the code with unordered_map to save the functions, user passes the argument into interface function to call regarding sub-function.
Go back to your case, the concept may like this. (I assume sub-function won't return a value)
I recommend you visit the link for more detail.
If you want to add new sub-functions in future, you only need to add static function and add it into unordered_map.
#include <unordered_map>
#include <functional>
using MyFunctionType = function<void(int)>;
// public methods
unordered_map<string, MyFunctionType> commandFuncs()
  unordered_map<string, MyFunctionType> my_dict;
  my_dict["wrist"] = callWrist;
  my_dict["elbow"] = callElbow;
  my_dict["shoulder"] = callShouder;
  return my_dict;
void armCommand(const string& command, float arg)
  auto dict = this->commandFuncs();
  auto it = dict.find(command);
  if (it != dict.end())
    return it->second((int)arg);
  else
    throw invalid_argument("command is not exist");
// private methods
static void callWrist(int arg)
  wrist(arg);
static void callElbow(int arg)
  elbow(arg);
static void callShoulder(int arg)
  shoulder(arg);
