9
LIDARs use a pulse of light to measure distance, usually from the time of flight to reflection and back. With a collection of these measurements they can determine their surroundings in two or three dimensions. LIDARs are used as one of the sensor systems for self-driving cars, in addition to cameras and other radar systems.
Robotic cars are still in the testing phase, but at some point in the future we can expect a busy intersection filled with them, trying to navigate their way through it. With multiple scanners per car, and possibly multiple beams per scanner, interfering signal sources could go over a hundred even in smaller stages.
When time of flight is used to measure the distance to the reflection, the interfering signals would produce multiple "distances", and it would most likely require multiple scans of the same point to average some kind of a reliable value from all the noise.
How do LIDAR systems differentiate their own signals from other sources? With the example of robotic cars, could this interference lead to an error state where traffic could gridlock from lack of valid data? Or is this even a problem?
One could use lasers with slightly different wave length - just as different channels for Wi-Fi signal. Also there could be used some kind of wave modulation... but I don't think LIDARs use such solutions, since laser point is so small, that case of interference with other sensor is... kinda, rare event.
I experienced interference of distance sensors, but with ultrasonic measurement, when 3 robots with multiple (12) sensors were working in distance of ~3 meters between each other. Never had this problem with LIDARs, though.
Is this even a problem in robotic cars? It should'nt be. Error correction and having high quality enviroment maps are the main reasons of putting multiple LIDARs and camera systems on intelligent cars. Distance measurement fail of one sensor, or interference with other car's LIDAR system (which is, as written before, a rare event) should not cause system to collapse.
As You wrote, robotic cars are still in testing phase, so any interference between multiple sensors working on giant intersection, are yet to be (or hopefully not) problems and sensor engineers will have to face them.
  • $\begingroup$ I guess only the manufacturers know if there is an issue with large scale use, those things are a bit expensive to test that properly. Though there's some nice technology on the drawing board, those next gen devices will probably have that managed as well. $\endgroup$
    – Hrulga
    Oct 4, 2016 at 1:59
  • $\begingroup$ I don't find this answer convincing. In particular, you haven't answered the question: "How do LIDAR systems differentiate their own signals from other sources?" Furthermore, your statement that testing of multiple LIDAR systems has not been considered is completely unfounded. $\endgroup$
    – JSycamore
    Oct 6, 2016 at 13:58
    $\begingroup$ I doubt your experience with ultrasonic interference can help with a LiDAR question. The technologies have very different characteristics. In particular LiDAR is highly directional - it rejects light not bounced directly back along the outgoing beam path. It is incredibly unlikely that even if the beam of another system was exactly on that path, and at the same frequency, pulse length and rep. rate that it would interfere for more than one sample, of which there are probably 100's of thousands a second. Deliberate jamming is another matter entirely. $\endgroup$
    – Mark Booth
    Oct 11, 2016 at 9:29
5
Based on two different company's sensors for use in autonomous cars - yes they do interfere. And honestly, I am not sure what is going to happen when you have 30 cars in an intersection, the noise will be horrendous and they will not work.
Radar systems from certain makers do not have this problem because they put "squark ids" in their signals which are quite unique and mitigate this issue.I would think you could do similar with the Lidar signal, but they dont.
In my opinion. Lidars are not a good idea for autonomous vehicles. Not just for the above problem, but there are about a dozen unsolved issues with them in the use of moving, high vibration environments.
If you are using Lidars. Test extremely thoroughly, especially on mobile systems. For alternatives: Solid State Lidar, mmWave Radar, and depth sensors (various types).
  • $\begingroup$ If you are correct, which seems intuitive, this is a problem that is a dark secret of the autonomous car projects. Besides the noise issue, jamming would be very easy to accomplish with liar. $\endgroup$ Nov 26, 2022 at 2:27
