I have a launch file for gazebo that works fine in terms of loading the robot into the world. But the problem I have is that I have to keep ending Gazebo in terminal by using CTRL + C and then wait for it to stop fully and then relaunch it with the new changes. Is there a more efficient way to load new changes to Gazebo? I have tried searching online but I couldn't find anything that I understood. My launch file is included below:
<?xml version="1.0"?>
<launch>
<param name="robot_description" command="xacro '$(find my_robot)/urdf/my_1st_robot.urdf.xacro'"/>
<node pkg="robot_state_publisher" type="robot_state_publisher" name="robot_state_publisher"/>
<node pkg="joint_state_publisher_gui" type="joint_state_publisher_gui" name="joint_state_publisher_gui"/>
<include file="$(find gazebo_ros)/launch/empty_world.launch">
    <arg name="paused" value="false" />
    <arg name="use_sim_time" value="true" />
    <arg name="gui" value="true" />
    <arg name="headless" value="false" />
    <arg name="debug" value="false" />
</include>
<node name="spawning_urdf" pkg="gazebo_ros" type="spawn_model" args="-urdf -model my_1st_robot -param robot_description"/>
</launch>
Thanks!
There is a package called xacro live, which may do what you want: https://github.com/orise-robotics/xacro_live But I haven't used it myself yet.
  • $\begingroup$ Thanks for sending that, but its for ROS2. I am using ROS1 Melodic. $\endgroup$
    – Balen
    Commented Jan 18 at 10:12
  • $\begingroup$ At least in ROS2, Gazebo has a service ros2 service call /spawn_entity. This way you can spawn new things while it runs. There is also delete_model to remove things, which works for ros(1), see gazebo_ros_pkgs repo issue $\endgroup$
    – Scoeerg
    Commented Jun 16 at 11:04
