how are you all doing?
I've been trying to use the ros humble robot_localization package to estimate my robot's pose using odometry and imu data. The thing is, when the fixed frame is the base_footprint all the robot's TF are parsed ok.
enter image description here
When I set my odom frame as the fixed frame some of my transformations break.
But if I look at the broadcasted frames the tf tree seems normal.
Although it isn´t something critical to me, it is bothering me a lot.
Thanks in advance.
Your /tf timestamp values are not consistent. Most likely you have some nodes with use_sim_time parameter set to true, and other nodes with it set to false.
  • $\begingroup$ It worked! Thank you very much! $\endgroup$
    – amsantos
    Jan 19 at 18:36
