My node which is a critical component of a larger system contains the following interfaces for communicating with other nodes
  1. Two action servers
  2. One tf listner
  3. One service server
  4. Four subscribers
  5. Two publishers
[running in ros 2 foxy in docker container]
I recently implemented the lifecycle version of this node and the idea was to deactivate the node when not required and save on CPU usage. I followed the following practices while implementing the lifecycle version:
  • Defined all parameters in constructor of class
  • Initializing pubs,subs,srvers etc all in on_configure callback.
  • Activating things which could be activated in on_activate callback and controlling rest with bools
  • Deactivating things which could be deactivated in on_deactivate callback and resetting the bools for all others
  • resetting all pointers in cleanup
My external code which controls the lifecycle of this node uses activate and deactivate states while in operation and configure / cleanup only once per run.
The CPU usage before on_configure is less than 1% which is expected. It goes to 15% on configure but it doesn't change much on activate or deactivate. (The compute might be going in spinnig and waiting i guess but not sure)
so activating and deactivating is not really giving me what i needed. I tried moving a few things from cleanup and configure into deactivate and activate CBs and got some improvement like the tf_listner it saved me around 4-5% of cpu. But the rest is still being utilized under the hood in spinning I guess.
Can we do anything else to reduce the usage further ?
I'm going to speculate its your TF system. TF is not a lifecycle system, so unless you're resetting the TF buffer / listener in on_deactivate, you're still processing incoming transformation information. Also, subscribers similarly have no lifecycle eq. I'd look at resetting those in on_deactivate as well.
  • $\begingroup$ Yes, the tf_listner was taking some of the usage and after resetting it saved 4-5%. I'll try resetting the subscribers too. what about service and action servers? should they be reset as well? $\endgroup$
    – tomRob
    Commented Jan 17 at 2:59
