I've build a few workspaces for different project but i never got any error, but this time, got this msg.
vyas@vyas-HP-Laptop-14s:~/ROS$ mkdir -p My_turtlesim/src
vyas@vyas-HP-Laptop-14s:~/ROS$ cd My_turtlesim/
vyas@vyas-HP-Laptop-14s:~/ROS/My_turtlesim$ catkin_make
Base path: /home/vyas/ROS/My_turtlesim
Source space: /home/vyas/ROS/My_turtlesim/src
Build space: /home/vyas/ROS/My_turtlesim/build
Devel space: /home/vyas/ROS/My_turtlesim/devel
Install space: /home/vyas/ROS/My_turtlesim/install
Creating symlink "/home/vyas/ROS/My_turtlesim/src/CMakeLists.txt" pointing to "/opt/ros/noetic/share/catkin/cmake/toplevel.cmake"
#### Running command: "cmake /home/vyas/ROS/My_turtlesim/src -DCATKIN_DEVEL_PREFIX=/home/vyas/ROS/My_turtlesim/devel -DCMAKE_INSTALL_PREFIX=/home/vyas/ROS/My_turtlesim/install -G Unix Makefiles" in "/home/vyas/ROS/My_turtlesim/build"
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_policy):
The OLD behavior for policy CMP0048 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
CMake Deprecation Warning at CMakeLists.txt:2 (cmake_policy):
The OLD behavior for policy CMP0063 will be removed from a future version
of CMake.
CMake Deprecation Warning at CMakeLists.txt:7 (cmake_minimum_required):
Compatibility with CMake < 3.5 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
-- The C compiler identification is GNU 9.4.0
-- The CXX compiler identification is GNU 9.4.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Using CATKIN_DEVEL_PREFIX: /home/vyas/ROS/My_turtlesim/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/noetic
-- This workspace overlays: /opt/ros/noetic
CMake Warning (dev) at /opt/ros/noetic/share/catkin/cmake/python.cmake:4 (find_package):
Policy CMP0148 is not set: The FindPythonInterp and FindPythonLibs modules
are removed. Run "cmake --help-policy CMP0148" for policy details. Use
the cmake_policy command to set the policy and suppress this warning.
/opt/ros/noetic/share/catkin/cmake/all.cmake:164 (include)
/opt/ros/noetic/share/catkin/cmake/catkinConfig.cmake:20 (include)
CMakeLists.txt:61 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.10", minimum required is "3")
-- Using PYTHON_EXECUTABLE: /usr/bin/python3
-- Using Debian Python package layout
-- Found PY_em: /usr/lib/python3/dist-packages/em.py
-- Using empy: /usr/lib/python3/dist-packages/em.py
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/vyas/ROS/My_turtlesim/build/test_results
-- Forcing gtest/gmock from source, though one was otherwise available.
-- Found gtest sources under '/usr/src/googletest': gtests will be built
-- Found gmock sources under '/usr/src/googletest': gmock will be built
CMake Deprecation Warning at /usr/src/googletest/CMakeLists.txt:4 (cmake_minimum_required):
CMake.
CMake Deprecation Warning at /usr/src/googletest/googlemock/CMakeLists.txt:45 (cmake_minimum_required):
CMake.
CMake Deprecation Warning at /usr/src/googletest/googletest/CMakeLists.txt:56 (cmake_minimum_required):
CMake.
CMake Warning (dev) at /usr/src/googletest/googletest/cmake/internal_utils.cmake:249 (find_package):
/usr/src/googletest/googletest/CMakeLists.txt:91 (include)
-- Found PythonInterp: /usr/bin/python3 (found version "3.8.10")
-- Found Threads: TRUE
-- Using Python nosetests: /usr/bin/nosetests3
-- catkin 0.8.10
-- BUILD_SHARED_LIBS is on
WARNING: package "moveit_task_constructor_core" should not depend on metapackage "moveit_planners" but on its packages instead
-- Configuring done (1.1s)
-- Generating done (0.0s)
-- Build files have been written to: /home/vyas/ROS/My_turtlesim/build
#### Running command: "make -j8 -l8" in "/home/vyas/ROS/My_turtlesim/build"
can anyone explain this, also how can i resolve this warning. (I'm using ros noetic on ubuntu 20.04)
These are the apt packages with catkin in there name:
ii python3-catkin-pkg 1.0.0-100 all catkin package library
ii python3-catkin-pkg-modules 1.0.0-1 all catkin package library
ii ros-noetic-catkin 0.8.10-1focal.20210423.221558 amd64 Low-level build system macros and infrastructure for ROS.
ii ros-noetic-pybind11-catkin 2.10.3-2focal.20230213.204608 amd64 A package vendoring recent versions of pybind11 and providing extra macros for easier integration.
I've updated the cmake version to 3.16.3 but i'm getting similar msg:
-- Check for working C compiler: /usr/bin/cc -- works
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- catkin 0.8.10
-- Configuring done
-- Generating done
catkin
in the apt package name. $\endgroup$cmake
you have installed. It should be v3.16.3. If you have upgraded cmake, your environment is not compatible with ros-noetic. $\endgroup$
