I am working with a robotic arm in simulation. I am using ros-noetic, gazebo and moveit for this purpose. I am using /robot_namespace as robot namespace, because of which robot joints data are being published on /robot_namespace/joint_states topic, in place of /joint_states.
I am trying to run below c++ code:
#include <ros/ros.h>
#include <moveit/move_group_interface/move_group_interface.h>
class MyRobot{
    public:
        explicit MyRobot(ros::NodeHandle nh);
        ~MyRobot();
    private:
        ros::NodeHandle nh_;
        const std::string ARM_PLANNING_GROUP = "arm_manipulator";
        moveit::planning_interface::MoveGroupInterface arm_move_group;
        const robot_state::JointModelGroup *arm_joint_model_group;
MyRobot::MyRobot(ros::NodeHandle nh)
  : nh_(nh),
    arm_move_group(ARM_PLANNING_GROUP){
      arm_joint_model_group = arm_move_group.getCurrentState()->getJointModelGroup(ARM_PLANNING_GROUP);
MyRobot::~MyRobot(){}
int main(int argc, char **argv){
  ros::init(argc, argv, "test");
  ros::NodeHandle nh;
  ros::AsyncSpinner spinner(1);
  spinner.start();
  MyRobot myRobot(nh);
  return 0;
but getting below error:
[ INFO] [1589572504.193567368, 922.494000000]: Didn't received robot state (joint angles) with recent timestamp within 1 seconds.Check clock synchronization if your are running ROS across multiple machines!
[ERROR] [1589572504.193719017, 922.494000000]: Failed to fetch current robot state
After doing some research, I found that arm_move_group uses default /joint_states topic, which is mapped to /robot_namespace/joint_states in my case via <remap from="joint_states" to="/robot_namespace/joint_states"/>
I have already tried some of the solution available online:
  1. Passing joint_states:=/robot_namespace/joint_states as argument to move_group node inside move_group.launch file.
    <node name="move_group" args="joint_states:=/robot_namespace/joint_states $(arg command_args)" ...>
  2. Passing <param name="use_sim_time" value="true"/> to move_group, robot_state_publisher and rviz nodes.
But none of the solutions seem to be working in my case.
I would really appreciate some help with this.
Thanks.
5
  • $\begingroup$ It looks like there is a joint_state_topic ros param in github.com/… that you could change. Also instead of remap from="joint_states" try remap from="/joint_states" with the leading slash. $\endgroup$ Jan 12 at 15:13
  • $\begingroup$ How should I change joint_state_topic ? Via launch file(like in move_group.launch) or directly in c++ code? And regarding adding leading slash in from="joint_states", I will do that. Thanks for pointing it out. $\endgroup$ Jan 12 at 17:30
  • $\begingroup$ I think only a moveit test (moveit_cpp) is setting the joint state topic to "/joint_states" instead of "joint_states" (the default according to github.com/ros-planning/moveit/blob/…). If you have the default then the answer below robotics.stackexchange.com/a/107574/884 applies and my suggested remap won't work. Alternatively setting joint_state_topic param in the launch file should work (though it's hard to say exactly where you set it to be in the right ns). $\endgroup$ Jan 14 at 17:10
  • $\begingroup$ remap from="/joint_states" is not working either. $\endgroup$ Jan 15 at 10:55
  • $\begingroup$ Ok try roslaunch some_package_name move_group.launch __ns:=/robot_namespace $\endgroup$ Jan 15 at 19:51
A more accurate statement is that arm_move_group uses the joint_states topic (with no slash) in the current namespace of your MyRobot node.
I think the cleanest way to fix this problem is to execute your MyRobot node in the correct namespace. If using a launch file, you do this with the ns= attribute of the <node> or <group> tag.
  • $\begingroup$ Can you please elaborate this a bit more like where should I put ns="" ? $\endgroup$ Jan 15 at 11:14
  • $\begingroup$ There is good documentation for the launch file syntax: wiki.ros.org/roslaunch/XML Click the link for <node>. $\endgroup$
    – Mike973
    Jan 15 at 14:13
  • $\begingroup$ What I meant was "execute your MyRobot node in the correct namespace" Can you please elaborate this a bit more? $\endgroup$ Jan 15 at 19:36
