Whenever I use following command
ros2 launch usb_cam camera.launch.py
Gives me the following error like this
[INFO] [launch]: All log files can be found below /home/ankit/.ros/log/2024-01-08-15-44-37-775903-ankit-vm-6485
[INFO] [launch]: Default logging verbosity is set to INFO
[ERROR] [launch]: Caught exception in launch (see debug for traceback): Caught exception when trying to load file of format [py]: If you use `@root_validator` with pre=False (the default) you MUST specify `skip_on_failure=True`. Note that `@root_validator` is deprecated and should be replaced with `@model_validator`.
For further information visit https://errors.pydantic.dev/2.5/u/root-validator-pre-skip
Can anyone help how would I use usb_cam
