I'm working on building a good Odometry estimation system for a quadruped Unitree robot (A1 and Go1). I've been trying to use ekf_localization node from the robot_localization package in ROS Melodic. Almost everything seems to work fine when I feed in sensor data through a rosbag, in the sense that, I'm able to get the fused odometry messages from the filter that correspond well with the ground truth.
Issue: But when my rosbag stops and none of the odometry and imu sources publish messages anymore, the node still keeps running and gives me erroneous results (basically a drift of the odometry in -ve z-direction). This happens at the end if I set imu0_remove_gravitational_acceleration: true and happens in the +ve z-direction if I set it to false.
Odometry sources and sensors: A VIO pipeline and a leg Odometry that returns linear velocity estimate from a RL controller. I use a single IMU source (publishes at 200Hz) and VIO runs on this IMU and a stereo Realsense d435i camera (realsense's imu not used). I re-publish all these messages at the same rate in the odom frame with child_frame_id as base_link for all the odometry sources.
I'm adding my config files for the ekf_localization node.
frequency: 50
sensor_timeout: 1
two_d_mode: false # The robodog can also climb over steps
publish_tf: true
transform_time_offset: 0.0 # For packages that require transforms to be future-dated by a small time offset
# transform_timeout: 0.0 # Zero to get the latest transform available and not block the filter
reset_on_time_jump: false # Reset the filter if a sudden time jump is detected
print_diagnostics: true # Print diagnostics information to the /diagnostics topic
predict_to_current_time: false # Extrapolate (predict) the state to the current time when no measurements received
disabled_at_startup: false # Start the filter as disabled
publish_null_when_lost: false
odom_frame: odom
base_link_frame: base_link
world_frame: odom
publish_acceleration: false
lo_topic: &lo_topic /ekf_vilo/leg_odom
odom0: *lo_topic
odom0_config: [false, false, false,    # Position
               false, false, false,     # Orientation
               true, true, true,      # Linear velocity
               false, false, false,    # Angular velocity
               false, false, false]    # Linear acceleration
odom0_differential: false
odom0_relative: false
odom0_queue_size: 100
odom0_nodelay: true
vio_topic: &vio_topic /ekf_vilo/vins_odom
odom1: *vio_topic
odom1_config: [true, true, true,   # Position
               true, true, true,    # Orientation
odom1_differential: false
odom1_relative: false
odom1_queue_size: 100
odom1_nodelay: true
gravitational_acceleration: 9.81
imu_topic: &imu_topic /imu
imu0: *imu_topic
imu0_config:  [false, false, false,
               true,  true,  true,     # Angular velocity
               true,  true,  true]     # Linear acceleration
imu0_differential: false
imu0_relative: false
imu0_queue_size: 100
imu0_nodelay: true
process_noise_covariance: [0.025, 0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0.025, 0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0.025, 0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0.05, 0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0.05, 0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0.05, 0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0.025, 0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0.025, 0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0.04, 0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0.01, 0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0.01, 0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0.02, 0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0.01, 0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0.01, 0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0.015]
initial_estimate_covariance: [1e-2, 0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    1e-2, 0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    1e-2, 0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    1e-2, 0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    1e-2, 0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    1e-2, 0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    1e-6, 0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    1e-6, 0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    1e-6, 0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    1e-6,  0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     1e-6,  0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     1e-6,  0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     1e-6, 0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    1e-6, 0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    1e-6]
Each odometry and sensor messages are as follows:
  1. Fused odometry from the ekf (Message from /ekf_vilo/odom) Message from /ekf_vilo/odom
  2. Imu messages (Message from /imu) Message from /imu
  3. VIO odometry (Message from /ekf_vilo/vins_odom) Message from /ekf_vilo/vins_odom
  4. Odometry from the leg (Message from /ekf_vilo/leg_odom) Message from /ekf_vilo/leg_odom
  • This is what happens when the IMU and the odometry sources (/ekf_vilo/vins_odom and /ekf_vilo/leg_odom) publish messages : The covariances are small and the fusion is good
enter image description here
  • This is what happens when the rosbag ends (and the covariances start to explode)
  • The odometry from ekf after the rosbag has ended (the odometry keeps drifting in the -ve z-direction)
I apologize for the extremely long message. Just wanted to be thorough!
Without new input data the ekf_localization node will simply continue to run its estimate that is based on the previous sensor data. The issue with the plus or minus Z drift is most likely a result of small acceleration errors from the IMU that accumulate into larger velocities. Some of this may be fixable using the ~dynamic_process_noise_covariance parameter but otherwise it's the intended behavior of the ekf_localization node.
There are a few options you can try to deal with this issue:
  • Remove the integration of the accelerometer's Z acceleration component. The RL gravitational acceleration removal (~imuN_remove_gravitational_acceleration) depends on the orientation of the IMU and results in a noisy acceleration value.
  • Decrease the process noise of the linear acceleration values in your process_noise_covariance matrix. Alternatively you can re-write the covariance field of the Imu message and increase the corresponding fields for linear acceleration. Higher variances in the sensor readings result in slower integration of the readings, for noisy sensor measurements this is preferred. It's generally not preferred to have 0 variances on the diagonal of the sensor readings, this results in the ekf_localization node populating the measurement variances with 1e-9 to keep the filter stable.
  • Use the use_sim_time parameter. When playing data from a ROS bag file, you can use the time information from the bag to drive your system instead of your system clock (read more here). When the bag ends, the clock will stop, and your localization node will stop producing new estimates. This doesn't solve the issue, it will only mask it, but in my experience it's the best way to test localization on bag data.
  • $\begingroup$ Thanks for the feedback. I will try these and let you know how it goes. $\endgroup$
    – Deepak
    Commented Jan 2 at 17:11
  • $\begingroup$ 1) I had to remove the integration of all 3 acceleration components. Otherwise the drift was either in x or y direction, which was weird. 2) Decreased process_noise_covariance for linear acceleration and increased the linear_acceleration_covariances by republishing the imu message. This was the most effective, and it slowed down the integration drastically. 3) Tried setting use_sim_time parameter as true, but this leads to the ekf filtered odometry not being publshed because there are no messages published by the /clock. Not sure why. $\endgroup$
    – Deepak
    Commented Jan 2 at 18:45
  • $\begingroup$ when setting use_sim_time you need to also add --clock to the rosbag play command. This forces rosbag to publish /clock otherwise it won't be populated. $\endgroup$ Commented Jan 2 at 20:20
  • $\begingroup$ Perfect! That worked for me. $\endgroup$
    – Deepak
    Commented Jan 2 at 21:31
