I want to use Pocketsphinx on my ROS2 workspace, but wanted to try it out on Turtlesim first. While building my workspace with
colcon build --packages-select pocketsphinx_package
I alwalys get this error:
CMake Error at CMakeLists.txt:13 (find_package):
  Could not find a package configuration file provided by "pocketsphinx" with
  any of the following names:
    pocketsphinxConfig.cmake
    pocketsphinx-config.cmake
  Add the installation prefix of "pocketsphinx" to CMAKE_PREFIX_PATH or set
  "pocketsphinx_DIR" to a directory containing one of the above files.  If
  "pocketsphinx" provides a separate development package or SDK, be sure it
  has been installed.
I installed pocketsphinx using the follwing commands:
sudo apt update
sudo apt install pocketsphinx
    $\begingroup$ Where did you find ROS 2 pocketsphinx bindings? All I could find is ros-pocketsphinx which is not compatible with ROS 2. $\endgroup$ Dec 30, 2023 at 23:32
    $\begingroup$ You're right, I didn't even check if it was compatible with ROS2! So I can't use pocketsphinx? Do you know another speech recognizer I can use? $\endgroup$
    – metaje
    Jan 4 at 13:56
You have probably not installed the development files for this library. Use apt to search for an apt package named something like pocketsphinx-dev and install it.
  • $\begingroup$ I searched for it and libpocketsphinx-dev is already installed. I also tried to set CMAKE_PREFIX_PATH to the right path, but I still get the same error. $\endgroup$
    – metaje
    Dec 30, 2023 at 23:00
