thisis my example xacro file and I need to change robot_namespace property's value
<?xml version="1.0"?>
<robot name="turtlebot3_waffle_pi_sim" xmlns:xacro="http://ros.org/wiki/xacro">
<xacro:property name="robot_namespace" value="robot1"/>
  <plugin name="turtlebot3_waffle_pi_controller" filename="libgazebo_ros_diff_drive.so">
      <odometryTopic>${robot_namespace}/odom</odometryTopic>
  <odometryFrame>${robot_namespace}/odom</odometryFrame>
    </plugin>
</robot>
I am trying to format this file with xacro pathOfXacroFile robot_namespace:=robot2 but in the output it shows always the default value not the formatted one
You are trying to override the robot_namespace in the xacro file. For your scenario, you need to set the xacro property using a xacro argument (arg).
  • Modify your xacro file: Adding an arg means we enable the file to accept command line arguments. Let's make an arg for the robot_namespace.
  <!-- New arg to add with the same default -->
  <xacro:arg name="robot_namespace" default="robot1"/>
  <xacro:property name="robot_namespace" value="$(arg robot_namespace)"/>
  </plugin>
</robot>
  • Test with the same command in the question:
This will print the xacro file content with the required change. Hope this helps!
