I am following the tutorial Setting up a robot simulation (Webots) ROS2 Humble.
Here is my_robot.urdf file:
<?xml version="1.0" ?>
<robot name="My robot">
    <webots>
        <plugin type="my_package.my_robot_driver.MyRobotDriver" />
    </webots>
</robot>
Here is the part of robot_launch.py file:
my_robot_driver = WebotsController(
    robot_name='my_robot',
    parameters=[
        {'robot_description': robot_description_path},
Here is the part of my_robot_driver.py file:
class MyRobotDriver:
    def init(self, webots_node, properties):
        self.__robot = webots_node.robot
        self.__left_motor = self.__robot.getDevice('left wheel motor')
        self.__right_motor = self.__robot.getDevice('right wheel motor')
        self.__left_motor.setPosition(float('inf'))
        self.__left_motor.setVelocity(0)
        self.__right_motor.setPosition(float('inf'))
        self.__right_motor.setVelocity(0)
        self.__target_twist = Twist()
        rclpy.init(args=None)
        self.__node = rclpy.create_node('my_robot_driver')
        self.__node.create_subscription(Twist, 'cmd_vel', self.__cmd_vel_callback, 1)
    def __cmd_vel_callback(self, twist):
        self.__target_twist = twist
I want to take the robot_name from robot_launch.py file and use it inside the MyRobotDriver class of my_robot_driver.py file.
Following is the little part of my desired MyRobotDriver class code:
name = robot_name   # here robot_name comes from launch file
self.__node.create_subscription(Twist, f'{name}/cmd_vel', self.__cmd_vel_callback, 1)
Is there any way to implement name = robot_name # here robot_name comes from launch file this line correctly? Here my_robot.urdf, robot_launch.py, my_robot_driver.py are from the tutorial.
