My task is simple: I want to move my drone manually around a room (IMPORTANT: I DO NOT WANT TO FLY IT) and I want to see its position update on a map using IMU data.
I've attempted something in ROS and Rviz, but the position on the map does not update when I pickup my drone from spot A and place it 5 meters away at spot B. It does however update when I fly the drone from A to B.
My question is this : is there someway I can do dead reckoning using the drone while not flying it? Or is flying the drone necessary to perform dead reckoning using the drone's IMU?
EDIT: Here's what my Rviz shows when I pickup the drone from A and put it at B. As you can see, orientation is updated, but the position remains the same. However, when I fly the drone, I can see the red arrow move around the map.
enter image description here
Any help would be greatly appreciated!
EDIT : The duplicate question just asks for general solutions. Here I've found a solution, I just can't get it to work; I need help debugging.
