Right now I am unable to execute the moveit and i am not sure why, I thought it could be due to Async Spinner but when i added a async spinner in the main or in the class itself it always aborts plannning saying it cannot plan but when i tried it with a different program it is able to reach the object
// Mutex for synchronizing access to the detected_objects vector
std::mutex detected_objects_mutex;
std::vector<geometry_msgs::PoseStamped> detected_objects;
// Callback function for the object detection subscriber
void ObjectDetectionCallback(const aricc_vision_msgs::ObjectArray::ConstPtr& msg)
    std::lock_guard<std::mutex> lock(detected_objects_mutex);
    int cnt = 0;
    for (auto& obj : msg->objects)
        geometry_msgs::TransformStamped transformStamped;
        static tf2_ros::TransformBroadcaster tf_broadcaster;
        std::cout << "[" << ++cnt << "] Detect object: '" << obj.name << "'." << std::endl;
        geometry_msgs::PoseStamped pose;
        pose.header.frame_id = obj.name;
        pose.pose.position = obj.position;
        // Fix: Assign Quaternion components individually
        pose.pose.orientation.x = obj.orientation.x;
        pose.pose.orientation.y = obj.orientation.y;
        pose.pose.orientation.z = obj.orientation.z;
        transformStamped.header.stamp = ros::Time::now();
        transformStamped.header.frame_id = "camera_color_optical_frame"; // Parent frame
        transformStamped.child_frame_id = pose.header.frame_id; // Child frame
        transformStamped.transform.translation.x = -pose.pose.position.y; // Object position x
        transformStamped.transform.translation.y = -pose.pose.position.x; // Object position y
        transformStamped.transform.translation.z = pose.pose.position.z;
        tf2::Quaternion q;
        q.setRPY(1.57, -1.57, -pose.pose.orientation.z);
        transformStamped.transform.rotation.x = q.x(); // Rotation
        transformStamped.transform.rotation.y = q.y();
        transformStamped.transform.rotation.z = q.z();
        transformStamped.transform.rotation.w = q.w();
        detected_objects.push_back(pose);
        tf_broadcaster.sendTransform(transformStamped);
// ObjectDetection class definition
class ObjectDetection : public BT::SyncActionNode
public:
    ObjectDetection(const std::string& name, const BT::NodeConfiguration& config)
        : BT::SyncActionNode(name, config), node_(""), listener_(buffer_)
        // Subscriber for object detection
        sub_ = node_.subscribe("/re_dl_detection/YOLOv8RotateObjectDetection/dl_output", 1000, ObjectDetectionCallback);
    // Define the input ports for the behavior tree node
  static BT::PortsList providedPorts()
    return {
        BT::InputPort<std::string>("object"),
        BT::OutputPort<geometry_msgs::Pose>("object_pose")
    // Execute the behavior tree node logic
    virtual BT::NodeStatus tick() override
        std::string object_name;
        ros::Duration(1).sleep();
        // Check if the required input "object" is missing
        if (!getInput<std::string>("object", object_name))
            throw BT::RuntimeError("missing required input [pose]");
            detected_objects.clear();
        ros::spinOnce();
        auto predicate = [&object_name](const geometry_msgs::PoseStamped& detected_pose) {
            return detected_pose.header.frame_id == object_name;
            int cnt = std::count_if(detected_objects.begin(), detected_objects.end(), predicate);
            if (cnt > 2)
                try {
                    // Lookup the transform
                    buffer_.canTransform("base_link1", detected_objects[0].header.frame_id, ros::Time(0), ros::Duration(1.0));
                    // Now perform the transform lookup
                    transformStamped1 = buffer_.lookupTransform("base_link1", detected_objects[0].header.frame_id, ros::Time(0));
                } catch (tf2::TransformException &ex) {
                    ROS_ERROR("Failed to lookup transform: %s", ex.what());
                    return BT::NodeStatus::FAILURE;
                // Extract and print the transform information
                move_target.position.x = transformStamped1.transform.translation.x;
                move_target.position.y = transformStamped1.transform.translation.y;
                move_target.position.z = transformStamped1.transform.translation.z;
                move_target.orientation.x = transformStamped1.transform.rotation.x;
                move_target.orientation.y = transformStamped1.transform.rotation.y;
                move_target.orientation.z = transformStamped1.transform.rotation.z;
                move_target.orientation.w = transformStamped1.transform.rotation.w;
                ROS_INFO_STREAM("Transform from base_link1 to " << detected_objects[0].header.frame_id << " received:");
                ROS_INFO_STREAM(move_target);
                setOutput<geometry_msgs::Pose>("object_pose" , move_target);
                return BT::NodeStatus::SUCCESS;
private:
    ros::NodeHandle node_;
    ros::Subscriber sub_;
    tf2_ros::Buffer buffer_;
    tf2_ros::TransformListener listener_;
    geometry_msgs::Pose move_target;
    geometry_msgs::TransformStamped transformStamped1;
class PickObject : public BT::SyncActionNode
public:
    PickObject(const std::string& name, const BT::NodeConfiguration& config)
        : BT::SyncActionNode(name, config) , move_group("gluon_arm")
    return {BT::InputPort<geometry_msgs::Pose>("PickObject")};
        if (!getInput<geometry_msgs::Pose>("PickObject", Pick_Object_))
        ROS_INFO_STREAM(Pick_Object_);
        move_group.setPlanningTime(5.0);
        ROS_INFO("hello im moving");
         move_group.setPoseReferenceFrame("base_link1");
         move_group.setPoseTarget(Pick_Object_);
         Pick_Object_.position.z = 0.1;
         move_group.move();
         ROS_INFO("i have finish movinig");
private:
  moveit::planning_interface::MoveGroupInterface move_group;
  geometry_msgs::Pose Pick_Object_;
// Main function
int main(int argc, char** argv)
    ros::init(argc, argv, "test_bt");
    ros::NodeHandle nh;
    // Behavior Tree Factory
    BehaviorTreeFactory factory;
    factory.registerNodeType<ObjectDetection>("ObjectDetection");
    factory.registerNodeType<PickObject>("PickObject");
    // Create Behavior Tree from XML file
    auto tree = factory.createTreeFromFile("/home/ubuntu/catkin_ws_qt/src/test_node/cfg/bt_tree.xml");
    // Logger for console output
    StdCoutLogger logger_cout(tree);
    NodeStatus status = NodeStatus::RUNNING;
    // Run the Behavior Tree
    while (ros::ok() && status == NodeStatus::RUNNING)
        status = tree.rootNode()->executeTick();
        std::this_thread::sleep_for(std::chrono::milliseconds(100));
    return 0;
  • $\begingroup$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. $\endgroup$
    – Community Bot
    Dec 22, 2023 at 22:34
