I have a LiDAR device that reports the entire 360 degree range, but split into scans of 22.5 degrees each, and I'm trying to assemble my LaserScan messages correctly.
As I understand, each 22.5 scan (17 measurements) will have its own message, but my confusion is regarding scan_time, which is defined as time between scans.
From this answer:
Think of scan time as the time taken for a full rotation of the sensor even if it's only producing data for part of that revolution.
Which makes sense for that particular question, because their sensor is only reporting a single range of angles, but mine reports a full rotation, albeit in multiple scans. Does the same "full rotation" argument works for my case? Or the time between scans in my case is the time for a single 22.5 scan?
Also this question this question tells me that I should use the time for a single 22.5 scan.
I interpret the comment in LaserScan.msg to mean it is the interval, in float seconds, from the start-of-LaserScan-msg-N to start-of-LaserScan-msg-(N+1).
That said, I don't think this field is very critical, and I suspect you could probably set it to 0.0 without a problem.
For what it is worth, I've never seen a ros driver output distinct LaserScan messages with 22.5 degree arcs like you describe. It's far more typical for the ros driver to assemble a single message with 360-degrees of data in it.
