How can I organize the model structure when using gazebo? I have a world file which include a robot with
        <model name='robot'>
            <pose frame=''> 0 0 0.94 0 -0 -1.57</pose>
            <include>
                <uri>robot</uri>
            </include>
        </model>
For the robot, I want to define a wheel that is used multiple times for the robot. I tried to include it as
        <link name='left_wheel_body'>
            <pose>0. 0. 0. 3.14159 0. 3.14159</pose>
            <include>
                <uri>wheel</uri>
            </include>
        </link>
        <joint name='left_wheel_joint' type='revolute'>
            <child>left_wheel_body</child>
            <parent>base_body</parent>
and wheel model.sdf looks like
<sdf version='1.7'>
    <model name='wheel'>
        <link name='wheel_body'>
            <inertial>
                <pose>0 0 0 0 -0 0</pose>
                <mass>0.5</mass>
            </inertial>
            <visual name='wheel_body_visual'>
                <geometry>
                    <cylinder>
                        <length>0.01</length>
                        <radius>0.02</radius>
                    </cylinder>
                </geometry>
            </visual>
        </link>
    </model>
</sdf>
The structure of the file is defined as
├─ robot
│  ├─ model.sdf
│  └─ model.config
├─ wheel
│  ├─ model.sdf
│  └─ model.config
└─ simple_world.world
However it kept saying that Error: Non-unique names detected in type model in Does anyone know how to fix this? Also I am including the absolute path to include wheel and robot into world file. But I is there a way to include relative path to include those model into the world / sdf file?
Thank you
  • $\begingroup$ I am only including wheel.sdf once currently to test it. But it still complain about non-unique name $\endgroup$
    – Max
    Commented Dec 22, 2023 at 0:57
  • $\begingroup$ Updated my answer. $\endgroup$
    – Mike973
    Commented Dec 22, 2023 at 13:04
  • $\begingroup$ If one of these answers helped you, please click the checkmark to turn it green. $\endgroup$
    – Mike973
    Commented Jan 21 at 17:21
You can add a name tag in your include to override the name in the included sdf, see the SDFormat specification.
For the relative path, use <uri>model://file.sdf</uri> and set the environment variable
  • GAZEBO_MODEL_PATH for Gazebo Classic,
  • IGN_GAZEBO_RESOURCE_PATH for Ignition Gazebo <= 7, or
  • GZ_SIM_RESOURCE_PATH for Gazebo Sim >= 7.
See also this GitHub thread.
  1. In sdf, if you <include> a model more than once at the same level, you must also provide a unique <name> tag for it. This is used to uniquely name that instance of the object.
  2. Also, I think your <uri> tag should look like <uri>model://wheel</uri>
  3. I doubt you can reference model 'robot' from inside <model name='robot'>
  4. According to the sdf specification, <include> is not a valid child of tag <link>.
